Originally Posted by jeanyes
Could one of you guys see how small of an image you can get into focus? I would like to use the W6000 (or W7000) for projecting patterns for a structured light scanner but need to know how SMALL of an image can be focused. If anyone could take a few minutes to do this I would greatly appreciate it. All I really need to know is the Width. I can then calculate the height and diagonal. Thanks!
Jean
Jean
Setting the PJ just 1' away from a surface, you could get a 3" x 6" projected image. In actuality, you could go even smaller...but visible resolution would be at best problematical.
But with the degree of brightness you have to deal with (...over 7500 foot lambert...) you'd need to project onto a ultra Black surface.
Of course, you can move upward in size from there to whatever parameter you want.
