There is processing going on no matter what in our video devices (nice theater btw). There is really no such thing as an unprocessed image anymore, though there are images that are less processed. Everything our devices are doing to get the image onto the screen is processing it. Did you know that some projectors sharpen the image even with sharpness at 0, and also that MOST digital cameras add essentially SOME sharpening to an image even when you have sharpening off when you take a picture?
The Darby doesn't affect all images the same and on some scenes it isn't worth it, but it adds a little bit of enhancement that can definitely improve the image when combined with other sharpening filters. Even in the original filmed source, the end result is remastered, processed, and filters are often added (sometimes in the re-mastering they add their own sharpening). It depends what you are doing and watching. The closest thing to a natural image would be on an ANALOG film (35mm, 70mm, etc...), but most movies are no longer filmed that way except for a few "showoff" ones.
http://www.imatest.com/docs/sharpening/
"The algorithm for standardized sharpening takes advantage of the observation that most compact digital cameras sharpen with a radius R of about 2 pixels (though R can be as low as 1 for DSLRs). This has been the case for several cameras I’ve analyzed using data from dpreview.com and imaging-resource.com. The algorithm for standardized sharpening is as follows."
MTFstandard( f ) = MTF( f ) (1- ksharp cos(2πR f/dscan)) / (1- ksharp )
where sharpening constant ksharp is set so MTFstandard( feql ) = MTF(0) = 1. fN = dscan/2 is the Nyquist frequency; feql = 0.3 fN ; feql = 0.6 MTF50 for seriously blurred edges where MTF50 < 0.2 fN.
Edited by coderguy - 1/25/13 at 5:06pm
