There is limitation with LED technology as far as lumens right now. They are pushing hard to get to 700 lumens or so, but there is also talk that they look brighter than the same lumens from a lamp. With time LEDs will get brighter, but I'm not sure how fast that will happen. Green seems to be the most limited right now, but with the Vivitek they just run the green for half the time and blue and red get about a quarter of the time each.
If they open irises up all the way they can get more lumens, but at the expense of native on/off CR. I would prefer to see things like the Sharp 12k and JVC where the user gets to choose between going brighter or higher native on/off CR instead of forcing people into one. If that one is chosen as middle ground it can hurt both sides (not as many lumens as some people would choose even with lower native on/off CR and not as much native on/off CR as others would choose even with lower lumens).
I preferred the 12k. I just set it up with a screen that gave me about 2.4 gain to my main position, so close to the same white as the 9000 with a 1.0 gain screen, but with way better blacks overall in real content and with the ability to go way brighter in ft-lamberts to that seating than a 9000 on a 1.0 gain screen.
And why prefer a 9k when all you had to do was use the high lumens mode of the 12k for what was likely a little bit better on/off CR and maybe even a few more lumens than the 9k?
Originally Posted by Digital2004
the search for ultimate contrast should not be at the expense of brigthness as imho screen sizes get bigger (the average or what people want) over time.
i have lots of clients who want the 300-450cm wide screens (add microperforations (not talking of woven models, ansi and lumens KILLERS (ie -40%) and you NEED something "capable" (withouth breaking the bank account for most people... sic).
Why purposely keep the higher CR modes out for the people who can live with less lumens? Does that accomplish anything for those who need higher lumens? For instance, if you have a client who needs 500 lumens should they have to live with grayer blacks because somebody else needs 1000 lumens and providing 1000 lumens would mean less CR (just the way light and the technology works)? And should the client who only needs 1000 lumens have to live with even grayer blacks because somebody else needs 2000 lumens? The Sony Qualia is a good case in point. They gave the choice to the user with about 2000 lumens for the brightest mode when the bulb was new, but with low on/off CR. Should they have just locked the projector in that mode and not allowed the higher on/off CR modes? And what would it have accomplished if Sharp had locked the 12k or 20k into the highest brightness mode? It wouldn't have helped those who need more lumens and neither would JVC having locked the iris open instead of giving users a choice.
I think people should be told that the lumens spec and on/off CR spec aren't for a single mode and at least JVC professional gave a small indicator in the specs on their site where the CR spec says, "Native: 50,000:1 (max.–depends on aperture setting)".
I understand that some people need more lumens. If a person wants an acoustically transparent screen it may limit their choices and another person may decide that they are willing to give up the AC screen for something else (like higher contrast ratio). Rooms have different limitations for screen sizes and I like to see manufacturers addressing those customers who need more lumens, but I also think they should address those people who don't need (and maybe don't even want) more lumens. Especially when the only thing needed to address each is to leave it up to the user to choose. That also addresses the market who only needs or wants the brighter mode some of the time (like TV with the lights on, some video games, etc.)
One advantage of dynamic irises is that they can basically provide the max lumens and max CR at the same time. Kind of simplification, but basically true. So, this W6000 might work well for people who need both and can live with the issues with dynamic irises. But it also depends on how good the dynamic implementation is.
Also, LEDs systems bring something new where the LEDs can be used for the modulation and then they could go to things like the Sharp, Qualia, or latest JVC where the user can choose the iris position which then determines a tradeoff between lumens and native on/off CR. And neglecting to put in irises so the user can choose doesn't really help anybody other than saving a little bit of money for implementation or maybe making some people frustrated that they can't get both the higher lumens and the higher native on/off CR when they never could have gotten that combination to begin with anyway. That is, leaving out the higher native on/off CR option wouldn't have helped the native on/off CR for the high lumens mode unless it meant lower maximum lumens.
So, those who want maximum lumens might be better off with manufacturers putting in options so the user can choose between max lumens and max CR. Otherwise the manufacturers might pick something in the middle and make everybody live with that. Seems to be what has happened with this new Vivitek LED DLP so far. The iris in the lens doesn't give the most lumens or the most native on/off CR, but something in between. With a system like Sharp's or even JVC's they could likely go brighter for those who need it.
--Darin
