post #1 of 1
I have some technical footage in the JVC W-VHS format, and I want to capture some clips at relatively low res avi (or mpeg) format.
The problem is that the JVC does not apparantly do NTSC/composite output if the source tape is 1080i; otherwise, I could use any old inexpensive capture card! (The unit will output either VGA or YPbPr).
Any thoughts on how to do this for <$1000?
Gerald C
