Eclectic2K and any others using my Setup Utility:
I just put a revised version on my web site (
www.the-gordons.net). It has better diagnostics, I believe the Music/Movie mode confusion is fixed, and I have added the code for Advanced setting for Master Volume and the reading of values from the Cinema11a.
Unfortunately the Cary does not yet have the capability for those two features in their firmware, but it has been requested...
If you switch to the new version, you will not be able to use any of the prior configurations you have saved. If this is a major issue let me know and I will write a quick converter.
Also when doing the installtion make sure the prior Cinema11A.DAT file located in the same directory as the application is deleted. That will cause the program to reinitialize the saved data to a default condition.
If before you load the new version you request a print file from the prior version, then you will have all of the prior values for all of the parameters except master volume obviously.
