AVS › AVS Forum › Audio › Speakers › Wall mount speakers suggestions?
post #1 of 3
Hello everyone I am new to this forum a few of my car buddies are on here and said I may be able to get some help on here. I am looking to purchase wall mountable speakers. I bought a denon avr-888 so that is what will be powering the speakers. I think the room is going to be hard to get good sound because of a it has high ceilings about 20 feet and the living room is all open leading into the kitchen/dinning room area. The reason I want to go with wall mounted speakers is b/c I am trying to keep the room looking simple and clean. It has a little room built that I call the central command room where all the electronics go.
I am not looking to go crazy on the amount of money I am spending because the house has a theater room that is built, wired but has no componets so I am saving my money for higher end stuff for that room.
Any suggestions, links, would be great.
Thank you
post #2 of 3
You need to supply some type of budget, because
Originally Posted by underpressure02 View Post
I am not looking to go crazy on the amount of money I am spending...
is very vague and open to all types of interpretation.
One man's "going crazy" is another man's " cheep garage system"
post #3 of 3
Sorry about that. I don't want to spend more then 600 for the speakers and sub. I also forgot to put down that I am looking for a 5.1 surround sound.
  Back to Forum: Speakers
