Originally Posted by
jjeff
^^^ where do you get the episode number? My Tivo occasionally shows episode numbers but for at least tonights Castle episode it does not, only gives it the title "Death gone crazy".
If they gave episode numbers and I let them build up I could actually watch them in the correct order, without the numbers I really have no way of knowing they are out of original order. Kind of wish they didn't mess with the original order!
I have my sources
While the production/episode numbers for a few shows of
Castle this season (so far) have been aired out-of-sequence, it doesn't necessarily mean that the shows were aired out-of-sequence. Sometimes, production needs result in episodes being produced out-of-sequence, after the production number was assigned. At this point in time, I have no data that says
Castle should be seen in production number order. More than likely, the DVD release (no Blu-ray releases so far) will put them in air order.
That said, a show that has be poorly treated by ABC is
Body of Proof. That series was horribly aired out-of-order and it showed.Story lines from early in the season were aired after episodes that referenced the early ones. And this happened for both seasons so far. Who knows what ABC is going to do to it this season.
Fox mistreated
Firefly when it aired. But, when the DVD was released, it specifically pointed out the correct order of the episodes.
