I'm having a problem with a drive line on my TV that I assume is being caused by a ground loop somewhere. My cable line doesn't have a ground at the house - it comes directly from the in-street box (where it is grounded) into an indoor splitter with no break in the line. I thought I would start by grounding it at the splitter to a cold water line, specifically the washer feed which is next to the splitter. Is this a good idea? Do I need to get a separate component or can I just take ground off the splitter where there is a screw which I assume provides ground.
Cable TV Line Grounding
AVS Top Picks
post #2 of 19
3/11/09 at 3:13pm
post #3 of 19
3/11/09 at 3:16pm
post #5 of 19
3/11/09 at 6:27pm
post #6 of 19
3/15/09 at 8:50am
post #7 of 19
3/26/09 at 11:49pm
post #8 of 19
3/27/09 at 4:58am
post #9 of 19
3/27/09 at 9:31am
post #10 of 19
3/27/09 at 1:33pm
post #11 of 19
3/28/09 at 3:10am
post #12 of 19
3/28/09 at 4:19am
post #13 of 19
3/28/09 at 5:11am
post #14 of 19
3/28/09 at 4:08pm
post #15 of 19
3/29/09 at 7:10am
post #16 of 19
3/29/09 at 3:06pm
post #17 of 19
3/30/09 at 1:07am
post #18 of 19
3/30/09 at 4:59am
post #19 of 19
3/30/09 at 5:16am
You don't think it's already grounded at the main service box?
No implication was intended. It was a question. You said you worked with Cox, so that's why I asked: "You don't think it's already grounded at the main service box?" That's the only logical explanation as to why the recent Cox guy removed the existing (hanging) grounding block and didn't properly attach it. I don't know, that's why I asked.
