BD Info for the FIXED version. First page updated.
Code:
DISC INFO:
Disc Title: PINOCCHIO_US_D1_BDLIVE
Disc Size: 30,577,247,697 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.4
PLAYLIST REPORT:
Length: 1:27:44 (h:m:s)
Total Bitrate: 36.31 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 28421 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
* MPEG-4 AVC Video 1669 kbps 480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio English 3446 kbps 7.1 / 48 kHz / 3446 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio English 192 kbps 1.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics English 31.039 kbps
Presentation Graphics English 65.299 kbps
Presentation Graphics English 2.438 kbps
* Presentation Graphics English 306.206 kbps
FILES:
Name Time In Length Size Total Bitrate
00001.M2TS 0:00:00.000 1:27:44.259 23,890,176,000 36,305
CHAPTERS:
Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:02:21.516 24,425 kbps 43,287 kbps 00:01:29.089 32,135 kbps 00:02:08.628 31,359 kbps 00:02:03.748 127,303 bytes 745,427 bytes 00:01:06.816
2 0:02:21.516 0:03:55.068 27,022 kbps 52,181 kbps 00:06:01.569 34,892 kbps 00:05:38.421 32,397 kbps 00:04:03.952 140,881 bytes 814,040 bytes 00:06:04.864
3 0:06:16.584 0:05:16.899 29,075 kbps 48,588 kbps 00:11:10.336 34,876 kbps 00:09:20.309 32,483 kbps 00:07:59.187 151,582 bytes 836,295 bytes 00:10:19.076
4 0:11:33.484 0:03:43.598 27,284 kbps 45,565 kbps 00:12:27.079 34,647 kbps 00:12:58.944 32,587 kbps 00:14:56.145 142,244 bytes 772,518 bytes 00:15:11.243
5 0:15:17.082 0:03:26.623 26,643 kbps 54,855 kbps 00:17:59.870 35,006 kbps 00:16:12.888 31,980 kbps 00:18:29.233 138,906 bytes 721,409 bytes 00:16:40.416
6 0:18:43.705 0:02:50.044 27,925 kbps 46,517 kbps 00:20:21.136 35,035 kbps 00:20:17.215 32,604 kbps 00:20:20.135 145,589 bytes 715,122 bytes 00:19:57.029
7 0:21:33.750 0:05:24.615 28,538 kbps 49,290 kbps 00:23:20.440 34,927 kbps 00:22:38.774 32,681 kbps 00:25:37.661 148,785 bytes 730,926 bytes 00:24:11.491
8 0:26:58.366 0:01:49.734 29,259 kbps 47,094 kbps 00:28:03.932 34,995 kbps 00:28:00.136 31,968 kbps 00:27:29.689 152,542 bytes 774,542 bytes 00:28:38.967
9 0:28:48.101 0:01:57.367 28,619 kbps 42,153 kbps 00:29:12.459 34,572 kbps 00:28:59.487 32,201 kbps 00:28:56.484 149,208 bytes 784,065 bytes 00:30:26.741
10 0:30:45.468 0:05:46.971 29,255 kbps 49,069 kbps 00:31:01.401 35,260 kbps 00:34:23.352 32,402 kbps 00:35:38.386 152,523 bytes 816,492 bytes 00:35:28.167
11 0:36:32.440 0:04:23.888 28,787 kbps 48,841 kbps 00:37:48.265 35,190 kbps 00:38:26.554 32,639 kbps 00:37:51.560 150,083 bytes 743,126 bytes 00:39:43.297
12 0:40:56.328 0:06:46.948 28,804 kbps 53,214 kbps 00:44:10.314 35,012 kbps 00:43:15.593 32,480 kbps 00:46:22.863 150,171 bytes 769,465 bytes 00:42:54.863
13 0:47:43.276 0:02:49.377 28,141 kbps 54,104 kbps 00:49:19.581 34,642 kbps 00:49:01.897 32,711 kbps 00:48:55.515 146,712 bytes 755,899 bytes 00:49:55.659
14 0:50:32.654 0:02:34.154 29,664 kbps 50,620 kbps 00:51:24.122 34,757 kbps 00:51:23.789 32,587 kbps 00:52:04.204 154,654 bytes 769,591 bytes 00:52:25.433
15 0:53:06.808 0:03:59.447 29,456 kbps 49,206 kbps 00:55:50.305 34,567 kbps 00:55:10.348 32,429 kbps 00:56:49.364 153,570 bytes 767,258 bytes 00:54:52.539
16 0:57:06.256 0:01:41.643 28,801 kbps 52,049 kbps 00:58:22.290 34,887 kbps 00:57:36.202 32,485 kbps 00:58:35.470 150,158 bytes 785,803 bytes 00:58:23.249
17 0:58:47.899 0:05:18.985 28,340 kbps 48,746 kbps 01:01:53.167 34,677 kbps 01:02:46.971 32,294 kbps 01:03:41.484 147,752 bytes 764,944 bytes 01:02:32.957
18 1:04:06.884 0:02:25.103 28,490 kbps 50,169 kbps 01:05:33.554 35,372 kbps 01:05:01.439 32,209 kbps 01:04:56.475 148,535 bytes 696,560 bytes 01:06:09.882
19 1:06:31.987 0:02:36.906 26,839 kbps 46,002 kbps 01:07:30.963 35,299 kbps 01:08:44.912 32,452 kbps 01:08:44.036 139,926 bytes 715,876 bytes 01:08:03.079
20 1:09:08.894 0:05:43.343 29,437 kbps 48,922 kbps 01:11:38.544 35,272 kbps 01:12:16.707 32,764 kbps 01:12:28.844 153,470 bytes 731,700 bytes 01:14:14.408
21 1:14:52.237 0:02:09.045 29,471 kbps 47,497 kbps 01:14:52.362 35,126 kbps 01:16:48.645 32,486 kbps 01:15:58.428 153,648 bytes 564,381 bytes 01:17:01.283
22 1:17:01.283 0:03:07.187 28,962 kbps 52,925 kbps 01:18:29.329 34,940 kbps 01:18:58.066 32,708 kbps 01:19:51.161 150,994 bytes 732,593 bytes 01:19:39.399
23 1:20:08.470 0:04:21.177 29,322 kbps 45,499 kbps 01:21:47.861 35,336 kbps 01:20:58.353 32,318 kbps 01:21:21.960 152,871 bytes 732,536 bytes 01:23:53.778
24 1:24:29.647 0:03:13.610 27,061 kbps 52,890 kbps 01:25:49.519 34,374 kbps 01:26:05.535 32,204 kbps 01:26:37.859 141,086 bytes 753,984 bytes 01:25:53.106
25 1:27:43.257 0:00:01.001 108 kbps 0 kbps 00:00:00.000 0 kbps 00:00:00.000 0 kbps 00:00:00.000 585 bytes 935 bytes 01:27:43.424
STREAM DIAGNOSTICS:
File PID Type Codec Language Seconds Bitrate Bytes Packets
00001.M2TS 4113 (0x1011) 0x1B AVC 5264.134 28,421 18,701,676,874 101,712,988
00001.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 5264.134 3,446 2,267,432,916 13,142,667
00001.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 5264.134 192 126,342,912 822,545
00001.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 5264.134 192 126,342,912 822,545
00001.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5264.134 31 20,424,345 120,989
00001.M2TS 4609 (0x1201) 0x90 PGS eng (English) 5264.134 65 42,968,977 245,619
00001.M2TS 4610 (0x1202) 0x90 PGS eng (English) 5264.134 2 1,604,102 9,439
00001.M2TS 4611 (0x1203) 0x90 PGS eng (English) 5264.134 306 201,493,396 1,121,419
00001.M2TS 6912 (0x1B00) 0x1B AVC 5264.134 1,669 1,097,966,351 6,036,666
Video: MPEG-4 AVC Video / 28421 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
* Video: MPEG-4 AVC Video / 1669 kbps / 480p / 23.976 fps / 16:9 / High Profile 3.2
Audio: English / DTS-HD Master Audio / 7.1 / 48 kHz / 3446 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
