Just got David Gilmour concert disk, but when it plays the audio is full speed, the video is half speed.
Using MPC-HC, using WMP 11 codecs. Have not had a problem until now.
I did notice that this is the first disk I have that is 30fps. I think all the others either VC-1 or AVC are all 24 fps. Not sure if that matters. Is there some setting inside WMP that I need to change or tweak?
Any help would be appreciated.
TH
TH
