Sorry for being a noob, but I have been doing research on HTiB's and I am still a little confused.
This passthrough thing I keep reading about. If I get a system that does not have passthrough that means I will only need the HDMI cable to carry both the audio and video signal correct? If I get one that does have passthrough that means that I will have to have a seperate cable for the audio or video? Or is it just a degradation of quality due to passthough?
What I want is a system that I can use with an HDTV+Cable Box+PS3, and only have to use 1 hdmi cable for each item. If you can recommend a good system for this I would appreciate it. I am looking at systems that run from $200-$700 range.
If I don't get any responses, I understand why.. but I would appreciate a little guidance if you have any to give.
. I will definitely look into that sony 7200.
