AVS › AVS Forum › Video Components › Home Theater Computers › How do I know Hardware Accceleration is working?
post #1 of 10
Ok, I know this is probably a stupid question, but how do I know if Hardware acceleration is actually working at any given time?
I have an Asus P5Q-EM board and an E8400 chip. From what I have read, the G45 chipset should automatically accelerate, but how do I know for sure it is working. I have used the Task Manager to check CPU usage and sometimes it can seem kind of high (40-50% or so) and I was expecting HA to take over more of the load. It's not a big deal, as the whole system is easily able to play back all my files smoothly, but my CPU is getting a little hotter than I like and I am wondering if this has anything to do with it.
For the record, I am playing back most DVD folder rips and 1080p Blu Ray rips using the guide in the "Blu-Ray to MKV, Options are Endless" thread.
post #2 of 10
Also, I am not using any outside programs for playback. I rely on VMC with the Media Browser plug in, and I don't launch into TT,PDVD or TMT.
I do have FFDSHOW and Hali installed though
post #3 of 10
VMC relies on directshow filters thus it depends on wheather or not the h264 directshow filter you have installed supports DXVA. What h264 directshow filter do you have installed? It you are only using FFDSHOW then NO you have no HA because FFDSHOW does not support it.
post #4 of 10
I don't have anything other than FFDSHOW, I don't think. What other ones are there that do support HA?
post #5 of 10
Well two of the more popular h264 filters that support HA are Cyberlink h264 (comes with PowerDVD 7/8/9) or mpcvideodec.ax (the standalone version of the h264 filter that comes in MPC-HC and it is free). The only thing is I am not sure if they support the g45 chipset. I know they support both nvidia and ati chipsets but not sure about g45.
post #6 of 10
I will look into those thanks, I do have PowerDVD installed, but I don't use it. I will see if I can get it working
In general though, how will I know they are working? Is it really just a matter of watching the CPU usage, or is there a program I can run at the same time that will show whether something is being accelerated or not.
post #7 of 10
Well, mpcvideodec tells you if you look in the filter properties while playing the video but I just googled it and found out that it does not support the g45 chipset for DXVA. Cyberlink does support g45 but it doesn't tell you anything. Just make sure the dxva checkbox is checked and check CPU usage. There is a piece of software called DXVA checker but once again not sure if it supports g45.
post #8 of 10
Checking if it's enabled versus working are 2 different things.
You could actually view some hi-def content with a lot of motion, and look for artifacts and any jerkiness. If that happens then HA is probably not enabled or not "working". E.G. nVidia broke hardware-assisted deinterlacing for the 7300GT in their recent 18x drivers. So actual viewing is the salient test.
post #9 of 10
easy get launch task manger and look at your cpu usage.If its 10% or lower then ha is setup
post #10 of 10
mr007 is right. I have an an old CPU (Opteron144) and I see 8-13% CPU usage while playing Blu-Ray@1080p (if I'm not running ReClock, too).
