Originally Posted by
DirtyDaygo0311
So I have had my 3600 for two days now. For one, can ayone help me with my network config? When I do my network connection test I pass 3 out of the 4 tests. I fail the last one, the internet service test. Anyone know what the issue could be and/or solutions. It worked yesterday for me beautifully.....watched netflix for three hours. Then later on that night and even now it is not working. Netflix and Pandora when I try to access them tell me I do not have an active connection to the internet. My computer is up and running perfectly though with the internet. Also has anyone else had an issue with playing Kung Fu Panda. It does not read the disc. Any help would be great thank you.
I will pop in Kung Fu Panda for testing, upon returning home this evening.
As for your connectivity issue, start by checking the obvious, which would be the connection between your player and the network. If you are running a wireless connection, do a search in this thread as there have been issues reported. If you are connected via a LAN cable, re-seat the connection at your 3600, as well as at the wall jack, and at the switch or router.
If you have any type of hardware router with firewall functionality between your modem and home network, it may be that it is still holding on to the IP address that the player was originally using, and that the pool of IP addresses may have run out. Reset the firewall, or better yet, get into your firewall's management console and remove the entry associated with your 3600, and then reboot your firewall, followed by your 3600. If you have run out of IP addresses, you may want to expand your range to accommodate additional devices.
Spence
