You fellows who are using big stacks (JBLsound4645 and Digital2004), what is your throw distance to your primary seating? The reason I ask is because the large stacks, being designed for long throws, are said to exhibit some strange issues in short throw situations. How does the stack resolve the issue of the relationship of distance between transducers and the throw distance? I would think that precise localization at home theater distances would be problematic. I also have heard that the big stack transducers comb filter each other and cause numerous problems at the crossover frequencies in short throw scenarios, but are not noticable in long throw situations. If the "home" theater is large enough, I would suspect that pro screen arrays designed for small cinemas would work fine. Just seems like the larger versions would bring problems. Tell us of more of your experiences with your systems.
AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › D-cinema Equipment and Theaters › Problems with Large Pro Cinema Stacks in Home Theaters?
AVS Top Picks
post #2 of 56
3/12/09 at 10:33pm
post #3 of 56
3/14/09 at 5:57am
post #5 of 56
5/9/09 at 2:18pm
post #6 of 56
5/11/09 at 9:04am
post #7 of 56
5/11/09 at 3:44pm
post #9 of 56
7/4/09 at 9:07am
post #10 of 56
7/5/09 at 6:53pm
post #11 of 56
7/6/09 at 12:11am
post #12 of 56
7/6/09 at 8:40am
post #13 of 56
7/8/09 at 9:30am
post #14 of 56
7/8/09 at 5:52pm
post #15 of 56
7/8/09 at 7:25pm
post #16 of 56
7/9/09 at 7:51am
post #17 of 56
7/9/09 at 7:52am
post #18 of 56
7/9/09 at 10:03am
post #19 of 56
7/9/09 at 5:21pm
post #20 of 56
7/9/09 at 8:13pm
post #21 of 56
7/10/09 at 6:03pm
post #22 of 56
7/11/09 at 6:52am
post #23 of 56
7/11/09 at 1:55pm
post #24 of 56
7/11/09 at 3:40pm
post #25 of 56
7/11/09 at 3:46pm
post #26 of 56
7/14/09 at 8:52am
post #27 of 56
7/14/09 at 6:24pm
post #28 of 56
7/14/09 at 10:52pm
post #29 of 56
7/15/09 at 5:56am
post #30 of 56
7/15/09 at 7:12am
AVS Top Picks
I feel kinda depressed sometimes, but I'm still gonna try to do it.
