I'm not particularly interested in frame interpolation, but I am quite interested in dark frame insertion (DFI) - loss in brightness notwithstanding - as a means of reducing/eliminating the 'sample and hold' (SAH) induced motion blur that affects many current projectors (especially LCD/LCOS). While the latter do suffer from some inherent motion blur as a limitation of the technology, I would think the SAH component is probably more significant, and remedying that would get one closer to the look of actual projected film (nicely replicated by the naturally decaying phosphors in CRTs).
I know the Sony VW200 incorporates this at the projector level, but are there any video processors that feature DFI, and if so, would they work with the current crop of projectors?
I would think DFI at the VP level would be a relatively simple feature to incorporate - simply adding in a black frame/image once every 24 seconds (1/48th of a second separated from the native frame/image) should almost certainly be easier to implement than interpolating a detailed image at the same frequency.
DFI as articulated above would result in 1080p23.98 material encoded on disc being fed to the projector as 1080p47.96 (23.98 image frames/second, and 23.98 black frames/second). The key question is whether current projectors would be capable of accepting such a signal. I know that many (all?) will accept 1080p24, as well as 1080p60 and 1080p50 (PAL), but will they accept 1080p48 (shorthand for 47.96)? The JVC RS-2 for eg. does not spec 1080p48 among accepted digital video timings/resolutions, but it does list a number of other timings/resolutions for PC signals, and the fact (I think) that it accepts 1080p24 input and doubles (or quadruples) it to 1080p48 or 96 suggests that it should (perhaps with a minor firmware tweak?) be able to accept a 1080p48 digital video input. Certainly the latter would not present any bandwidth issues, since the projector happily accepts 1080p60. I no longer have a Lumagen HDP, but someone could verify this by using a Lumagen (or HTPC, etc.) to feed an RS-2 a custom 1080p timing.
To recap:
1. Are there any VPs that perform DFI?
2. Can most currently available projectors (I'm particularly curious about the RS-2) accept a 1080p48 'custom' timing?
To recap:
