Note, this is now solved. See bottom for my resolution, which was essentially "RTFM you idiot."
Am hoping some wisdom on this board will guide me.
Caveat: I have zero experience with antennas or any HD beyond what Comcast used to give me.
Background: I have a HTPC with a Hauppage digital tuner card I am trying to utilize with an antenna.
I am in Palo Alto CA. I grabbed a Terk indoor antenna from Fry's last week, and simply tossing it near the ceiling I was able to get a handful of channels, albeit spottily. I decided to go outdoor, bought a ChannelMaster 3018 and put it together. All good seemingly.
It is on the roof, put together, I have attached the balun and coax to the balun, but no matter what I now do (or where I aim), the only channel I can get with the 3018 is NBC11.
Antennaweb shows NBC (and few other channels) to be available at 306 degrees; most other digital channels at 320 degrees. But I can't get any of these other channels.
Tips/advice all welcome. (Assembly instructions for antenna neophytes are less than ideal.) Have I perhaps connected the balun improperly? Will a signal amplifier take me from zero signal to green? Should I really expect the Terk indoor piece of plastic to best this 15-foot roof-mounted monstrosity??
thanks in advance, I can provide photos or more detail to anyone willing to help out.
As Steve noted, be sure to do a rescan now. If that doesn't work, I suggest that you start looking for something that might be preventing reception of UHF digital signals, whether that's a setting in your computer-based digital TV receiver, or some physical piece of equipment.
