I was just wondering if it is safe to use a vacuum on the vents on the back of a Pioneer 6010FD plasma or would people recommend not doing this? Can I damage the tv by vacuuming out the vents? Should the back vents be cleaned out?
I believe It is stated in the 5020 manual that this is an acceptable method for cleaning the vents. I would assume it would be fine for the 6010 as well.
