AVS › AVS Forum › HDTV › HDTV Technical › Blu-ray DVD skipping
post #1 of 6
Hi guys, have a problem with my TV and was wondering if someone might be able to help me! I've recently bought my first BluRay DVD, 2001: A Space Oddysey. Bought it because i thought it'd really show off full HD to the max, and it does!
However, when it moves faster (like on action scenes or when people walk or run), you can see that the image is skipping ever so slightly, like the TV can't keep up or something? It's not that annoying with a slow moving film, but then i decided to try '300', and with it being an action film, it really became very noticeable.
I'm using a PS3 as my BluRay player, and it's running through an LG 32" 1080p TV. I'm wondering if it might be some kind of FPS problem?
Thanks for any help.
Tom
post #2 of 6
How is the PS3 hooked to the TV? Have you checked to see how well that particular set handles fast motion?
You also may want to check the Blu-Ray and/or LCD Flat Panels sections of the forum, this one is more geared towards HD reception equipment.
Welcome by the way, good luck with your issue.
post #3 of 6
What resollution are you sending to the TV over what interface? You might try 1080i if you are currentll sending 1080p.
What is the model number of the TV?
post #4 of 6
It's a HDMI input mjones, and the TV normally handles fast moving videos (at standard def, say, on TV) perfectly fine. No skipping at all, so im liable to think it might be the player itself. However, i downloaded some 1080p trailers on the PS3 and they all play well without skipping. The TV isn't 100hz, so sometimes they can be a bit blurry, but no skippage!
Tried turning 24fps off but that did nothing. Any other ideas?
post #5 of 6
Tom,
If you are sending the same resolution and frequency to your TV for the BR DVDs that you sent for the trailers the TV should act the same.
Where are you located I ask since you mentioned that you do not have a 100Hz model which my mean that your are in as location with 50Hz power and and have a 50Hz model.
post #6 of 6
I live in the UK. That's what i mean though, the trailers play fine, the DVDs just seem to be skipping slightly.
  Back to Forum: HDTV Technical
