I had seen the Sensio in action about 4 years in one of those hi end stores in Naples FL. It was so cool but the price was not. $3k and not many, if any studio movies.
So fast forward 4 years later and I had the opportunity to pick up a new Sensio for way under $1K
I did a little research to find out if my TV (Mitsubishi WL82913) and Sony DVD player (DVP-CX985V) are compatible.
What I found you'll need to set the progressive-scan DVD player's output to interlace. Ok, no problem on that, the Sony has a switch on the back to go to interlace. I also checked the DVD's menu to make sure it's on interlace.
Next the TV has to be capable of displaying 480p with a VGA input. Now here's where I thought I have a problem. On my TV the VGA input is 720 and 1080p but there is another input called DTV and has RGBHV and are 480i/480p and so on.
I tried it on the VGA first, it had a picture and you can make out things on the screen, but there was no 3D effect.
Then I tried the RGBHV and all I got was a scrambled picture.
Anybody have any thoughts? TV not compatible? Maybe it's the DVD player?
