AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › Update via the internet?????
post #1 of 20
I have searched this forum top to bottom and everywhere in between and can't find a solid answer.
Does Toshiba still support FW upgrade via the internet or download to disc iso. file only.
Thanks in advance for your help.
RTROSE
Regards
post #2 of 20
I was not able to connect last week when I finally decided to go with 4.0 but iso disc worked fine.
post #3 of 20
I'll try today to see if I can connect via the internet, otherwise I'll try the iso file.
Did you do anything in particular for the download or burning of the iso file? I have overloaded my brain on threads here were people have had issues now I'm overly paranoid.
RTROSE
post #4 of 20
I just updated my a35 this am over the internet.
post #5 of 20
I used a cd-rw at low record speed and it was fine. Just took a while for the player to go throught the steps. DO NOT power off the unit it will do that when done. People have had the problem of thinking the update had finished or locked the unit and powered off the unit bricking it.
BTW A38
RTROSE
post #6 of 20
I just burned the V4.0 ISO to a CD-R and upgraded my A30 with no issues. Takes about 10-15 minutes and like Cal said, don't disturb the process in any way. Step 4 takes at least 5 minutes so be patient. When it's done the tray will eject so take out the disc and then you can test your player.
Be sure you downloaded the right firmware and that it unzips with no errors. And that your ISO burning program is reliable. Use a quality CD-R too. I used EMC 10 since I have it and like that after burning an ISO it verifies the disc.
I took the extra step of downloading the file twice and unzipped each to separate folders then used the DOS FC command to do a binary compare to be absolutely certain I didn't get a single bit corrupted somehow. I know, I know, paranoid...
post #7 of 20
Well tonight I was able to update both my A2 and A20 tonight via the internet. I was shocked that it went so smoothly. The process included 40 updates and five steps and took 25-30 minutes per player. I think this speaks very highly of Toshiba to continue to support these players and us the consumer. Now I get to see if the firmware update fixed the problem I was having with my Matrix discs. Sitting here with fingers crossed.
Oh and is it still wrong to be bitter about "My" format loosing the "Format War"? I guess even though we lost I still find it hard to wave the white flag of surrender when I still believe "our" format is superior? Sorry if it just sounds like sour grapes, but I do feel better now that I have gotten that off my chest.
RTROSE
post #8 of 20
RTROSE
Glad to hear you were able to update your units without any issues. As far as the format war is concerned, most of us have come to terms with it and have moved on. Your HD DVD player will hopefully give you years of enjoyment and if you can get in on the software bargains, it's even better!
post #9 of 20
Well tonight I was able to update both my A2 and A20 tonight via the internet. I was shocked that it went so smoothly. The process included 40 updates and five steps and took 25-30 minutes per player. I think this speaks very highly of Toshiba to continue to support these players and us the consumer. Now I get to see if the firmware update fixed the problem I was having with my Matrix discs. Sitting here with fingers crossed...
I just upgraded my second A30 with the CD-R I created from the V4.0 ISO. This time I timed the procedure and it took 11 minutes total with Step 4/4 taking about 8 minutes. I had the player plugged into an UPS just in case. All went well just like my first unit. As you said, kudos to Toshiba for their continued support of customers. Good luck with those disc problems.
post #10 of 20
Glad to hear your update went smoothly too. I understand the whole loose power during the update and brick your player thing had/has me paranoid as well. I made sure all in the house knew I was updating my players and to leave just about everything electrical alone.
RTROSE
post #11 of 20
Yeah my wife started the washer during the update. Arrrgggghhhh!
No problem though, I'm glad I had the UPS.
post #12 of 20
??????????????????? What does the washing machine have to do with the update?
post #13 of 20
You don't want major surges and transients on your house wiring when flashing firmware. It could brick your player or PC!
post #14 of 20
I don't know how many times I have read or have heard NOT to turn your player off during updating. The player actually tells you not to turn off. I like you Q, get a little paranoid during the update process. It would be just my luck for some freak power surge or outage to occur at the same time I decide to update. I share your paranoia (at least as far as power is concerned). 8-)
RTROSE
post #15 of 20
Are the Toshiba servers still up and running?
I tried several times today to update the replacement XA2 unit I got this week from Toshiba and it said cannot find out server every time.
I guess I will try again tomorrow.
Hopefully they are still running the servers?
post #16 of 20
They should be, however you must follow the directions in the manual to properly setup the connection. I was having the same issue with one of the two players I updated and it was the speed of the connection I had selected initially that was messing up the connection. Make sure all of your setting are correct and try it again to see if that helps.
RTROSE
post #17 of 20
my answer is yes they still support the update via internet maybe there is some server problem or whatever you should contact them.
post #18 of 20
DHCP => On
DNS => On
.. or be sure you enter the correct values if you set it manually
post #19 of 20
yes-I have DHCP & DNS On and the unit does obtain an IP address.
I'll play around some more today.
post #20 of 20
I just did an A3 to 4.0 with no issues. Servers are still active...
  Back to Forum: HD DVD Players
