Hey gang... so I'm about to pull the trigger and order a screen from Chris at SeymourAV.
What I'd really like to be able to do is press a button on my Insteon KeypadLink to make the screen go up and down.
SmartHome has this nice pic on their site:
But I think it assumes low voltage? Can anyone here help me figure out exactly how to make this work? I think I could do it with 2 IO Links or 1 EXIO2x4? But I'm not feeling very confident about the low vs/ line voltage application. Chris has some nice options which I'd be willing to consider, but I'd really like to link it in with the Insteon stuff I've already got. Hopefully one of you is much better with this than I am and can suggest a plan of attack.
Thanks a bunch!
- Insteon KeyPad Link
- IO Link - INSTEON Low Voltage / Contact Closure Interface ( 1 In / 1 Out )
- EZIO 2 Input/4 Output Relay Controller
- IO Link Relay Modes
- EZIO 2x4 Quickstart Guide
Thanks a bunch!
