AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Cabling software, does it exist?
post #1 of 2
Dear AVS members,
I have a question with regards to connecting my newly bought Pioneer equipment.
Is there a software available that allows you to pick all your components and it will automatically generate a cabling diagram for you?
Thanks a lot for your help and tips!
Best regards, Werner
post #2 of 2
No and there really shouldn't be since its not extremely difficult to connect all components together.
Every component has its own manual and it will have pictures to help you.
Sorry if that sounds too difficult but there are only so many ways to connect this stuff.
