AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Marantz UD9004 Universal player with Blu-ray
Marantz UD9004 Universal player with Blu-ray - Page 4
post #91 of 207
Originally Posted by edorr View Post
Yes. When you cross over the CBIII at 40Hz you get response way above 40Hz because of the "slope" of the filter. With the Marantz you need to cross over above 40Hz to get a more smooth bass response.
You can easily compare by hooking up the Marantz digitally to the CBIII and analog to the six shooter. Then you play a CD with L/R bass crossed over to LFE channel and turn off all your channels except the sub. You can now switch between the digital input into CBIII and the analog into SS. I find you will get substantially higher frequencies coming out of the CBIII even at 40Hz Xover setting than the Marantz at 80Hz setting.
My assumption here is Steve is using 6 dB Butterworth with the CB, and the Marantz is 12 or 24 dB.
post #92 of 207
I have been using Phase Perfect 6 dB with the CB3.
Hey, I made a bit of video adjustment to the 9004. Set black level to +1 and high sharpness to -1. Now the picture is sensational.
On the Marantz audio side, I went into the menu and turned that audio source or pure direct whatever it is off while I played the following Blu Ray, and I set the crossover to 80 Hz.
Just watched the 2006 "Casino Royale". WIW! The best video and sound I have ever had.
Twice I heard a sneaker squeaking on the floor from the suround left speaker. Yea, stuff we aren't supposed to hear but we did anyway.
That certainly wasn't intended as part of the soundtrack!!!
post #93 of 207
Thinking of upgrading my Denon 5910 to one of these things. Have any of you owners compared this Marantz to the 5910, or the DVD A1?
I'm mainly interested in audio quality, I assume the picture will be outstanding. Also I'll be running analog audio only, as I am using a Parasound Halo P7 analog mch preamp.
TYIA
PS Steve--glad to hear you're not Doug. I'd hate it if he was using my name...
post #94 of 207
OOPS!-- Might not fit my rack. I have 7 1/2 inches clearance. Marantz spec says 6 7/16 inches, but looking at the picture I'm thinking that does not include the feet. Can one of you guys help me out here with a tape measure?
Much appreciated.
post #95 of 207
TYIA
Reviews indicate that its the extra analog boards and thingamagics that make the Marantz rock analogwise over the Denon. Thats why I went the Marantz route. As I use my CB3 Theta Six Shooter as a multi-channel analog preamp.
post #96 of 207
Thanks, Steve. Now to find out if it will fit my rack, or is it back to the shop. Was gonna build a new one anyway, just thought I could wait a little longer.
Got tape?
post #97 of 207
It measured only a tad more than 6.5 inches from top to bottom including those biggie coper feet!
post #98 of 207
Thanks--that's good news. I guess it will fit if I go that route.
My other contender is the new Ayre universal player. That would be my dream player, but it not only costs much more, I would also have to buy a different pre-pro to accomodate the HDMI audio for multichannel movies or music. Not that I care so much about the mch music, but it's a must for movies.
Thanks again!
post #99 of 207
Thanks again!
As I am using my Theta CB3 and Six Shooter, the latter as the multi-channel preamp, the UD9004 with its outstanding multi-channel analog out suits me for blu ray, dvd, multi-channel sacd and dvd-a, and stereo sacd.
But I will continue using my PS Audio Perfect Wave Transport and DAC for redbook and higher rez stuff, too! The Ayre doesn't fit me because its got the fantastic stereo analog ouput but then HDMI for multichannel. And I think Bulldogger has hit the nail on the head when he says none of the SSPs are using ARC (Audio Rate Control) jitter reduction so sound from an excellent multichannel analog player like UD9004 into excellent multichannel preamp will be better than HDMI into the SSP.
post #100 of 207
Stll been burnin' the 9004 in a lot!
Today, don't laught, I watched the blu ray of "Stargate: Continum".
The picture has never ever been better. Could it be even better than my Oppo BDP-83? Could HD video over HDMI be better on the 9004 thanks to the power supply, etc of the 9004? It just might be!
I can for sure say the picture between "Casino Royale" yesterday and "Stargate: Continuum" today is as good as it has ever been. As for better, someday on a weekend I'll set up the Oppo and AB them both. But I am very very video happy!
I have definitely heard the multichannel SACD getting better. The bass has cleared up with burnin' in and now is outstanding. I played a James Taylor SACD in multichannel that I know very well and yea, hands down beats my old Compli on multichannel SACD.
Tonight I also played "Blood Seat & Tears 3" stereo SACD, for which I have balanced interconnects into the Theta Six Shooter. WOW! Stereo SACD has never sounded like this in my system before!
I am getting very, very impressed.
post #101 of 207
Same expience - the audio really opens up with more hours on the player. Just curious - are you using a multi channel or stereo disc for burn in? Not sure how the electronics really flow, but in theory if you burn in with 2 channel disc you are bypassing at least part of the multi channel circuitry. By the same token, if you burn in using source direct on sacd, you are bypassing the DSP circuitry. So - at least in theory - you should burn in using a multi channel source with source direct off (when you listen to SACD, you obviously need to switch back to source direct on).
post #102 of 207
Thanks again!
Read back my dialogue with Charles on the Ayre univeral forum. I had a debate going on (before buying the ud9004) about what would sound best on MC audio - ud9004 + Six Shooter, or Oppo 83 + CBIII with HDMI (I was still naively assuming Theta would deliver at this point). His view was the analog route would beat the HDMI setup. If you bought the Ayre instead of the Oppo things would get better because of the separate audio clock, but because of lacking ARC it would still be a very suboptimal implementtion of high rez MC audio. All this for the price of 10K fir the Ayre and another 10K+ for a very good HDMI capable SSP. The Marantz route would be cheaper and very likely sonically superior on MC. For 2 channel the Ayre promises to be beat the Marantz, but like steve I will be using the PS Audio PWD for this. In conclusion, if you spend 80% of your time listening to stereo CD and MC audio and video is secondary get the Ayre, a top notch 2 channel preamp with HT bypass and a half decent SSP (Integra comes to mind).
If BR and MC audio is important to you get the Marantz. Only problem is what MC analog preamp to get. No one in his right mind would buy a MC analog preamp at full price these days, but used Audio Research and Swtichman are rarely seen. You could also consider an SSP with good analog bypass (not sure which one to get). You could shop around for a six shooter and bare bones CBIII as a controller. This combo can be had for <3K i suspect.
post #103 of 207
I have varied the burn-in. Sometimes using two channel SACD, sometimes using multichannel SACD, sometimes using DVD, sometimes using blu ray,
sometimes using a redbook CD burn-in disc.
post #104 of 207
Thanks edorr.
I remember your discussion with Charles well, as I only found that thread recentlly, and just finished it a couple of days ago.
I have the mch analog covered, as I currently have a Denon 5910, running into a Parasound Halo P7. I also have a Nuforce AVP17 fed by my Dish DVR, and then running through the P7 in HT bypass mode. Little clumsy, but it works.
So, the Marantz would pretty much be plug and play for me, with no other upgrades necessary for now. Plus I found a killer deal on a new unit with full warranty, so I'll probably go that route.
But either way, I've recently discovered ADA products and am seriously considering either the ADA suite 7.1 HD at about 5.5K, or the Reference MachIV when they release the balanced version, about 7.5K.
http://www.ada.net/products/ht/suite...e19776d526ccff
http://www.ada.net/products/ht/cinem...sody_mach4.php
The most info I can find about these products comes from this thread on AVForums, our sister site in the UK. (Though the ADA is built right here in the good old USA)
http://www.avforums.com/forums/audio...te-7-1-hd.html
Check it out: seems like an incredible bit of gear. I'm still reading the thread, but it's about the same length as the DX-5 thread, with much participation by the British distributors and techs. It doesn't have the ARC to my knowledge but does some sort of reclocking. A couple of the participants in the thread heard it once and immediately sold their Arcam AVR888s.
Ther is an Ayre dealer in Santa Fe I'm going to check out. I may know someone at that location, but I'm leaning towards the Marantz, just because it requires no immediate further upgrades.
Thanks again.
post #105 of 207
Update--Spoke to someone at ADA. The balanced version of the Mark IV is available, same price as the unbalanced. Balanced outputs, but no balanced inputs. FWIW
Sorry if I'm OT
post #106 of 207
Well guys, I just went ahead and ordered a UD9004 from American Theater off of an audiogon ad. Brand new, warranty, good price. Should be here in a couple of weeks.
The big advantage for now is it will fit right in where I have my Denon 5910, and hopefully give a big improvement in music as well as movies. 'Bout time I got Bluray.
I'll put off any further decisions for a little while.
Thanks to all for your input. I'll report back when it arrives.
post #107 of 207
Thanks edorr.
Thanks again.
I have no doubt the ADA is a fine SSP, but in my view you either spend the money on a top notch D/A conversion in the player (i.e. the Marantz route), or the SSP (i.e. the ADA route). If you get the ADA, the Marantz would be serious overkill as an HDMI transport. Since it appears you went the Marantz route, I presume the ADA is no longer on your shopping list.
post #108 of 207
Give it some time to burn in an you will not be disappointed. I bought mine from the same seller and he is 100% legit and extremely responsive. Your parasound will do just fine as a preamp I trust. If an EMM labs switchman or audio research comes along on audiogon you could consider picking it up to take your system up another notch (last switchman I saw sold for 2,200 on A'gon auction).
post #109 of 207
I may just use the smaller ADA with the HDMI output of the Marantz and the optical output of my Dish DVR for all mch audio then get a higher end pre amp for the balanced 2ch output of the marantz, hopefully one with HT Bypass.
Got other things to deal with for now, so those decisions can wait.
post #110 of 207
If you go 2 channel analog and multi channel HDMI the Ayre would indeed have been your ideal player (theoretically anyway), but the Marantz should be a close 2nd at 40% of the (street) price.
The only drawback is that the Marantz will downsample MC SACD to 44/16, so if you have a big collection of MC SACD your target "HDMI for MC audio over ADA" configuration is suboptimal. If MC SACD is not a factor for you, your ADA + 2 channel analog preamp sounds pretty ideal. If MC SACD is a factor I would seriously consider picking up a used Six Shooter and bare bones CBIII instead, and here is why:
- This will give you a true MC channel analog preamp, which will be better on MC SACD, and unlock the full value of your Marantz
- Your cost will be around 3K, less than just the 2 channel analog preamp that is sonically equivalent to the Six Shooter (according to the resident Six Shooter experts on this forum - I cannot confirm based on personal experience)
- You can use your CBIII for Satelite reciever over S/PDIF
Incidentally, this is precisely what Steve and I are doing. Only thing is we are stuck with pricy Xtreme cards which we don't really need, but which you don't ever have to buy.
Only drawback is if one of your Theta components ever fails - given the current state of Theta you are SOL.
Anyway, you got yourself a nice upgrade with the Marantz out of the box, and with the Parasound as preamp there is no rush to do anything but enjoy the music short term.
post #111 of 207
Thanks for all your input edorr
I'm going to just put the Marantz in the sytem as is for now and enjoy for awhile, but eventually I want a pre-pro that will handle digital as well as analog, so I can plug in my DVR as well.
The flagship ADA Rhapsody Mach IV Balanced version has both analog multichannel inputs and HDMI, so I could hook up the Marantz either way and see which I preferred . It also has balanced ouputs (no balanced inputs, unfortunately)
That still leaves open the option to add a 2ch preamp later, though if the reports I read on the ADA stuff are to be believed, it may not be necessary.
It seems to have incredible setup flexibility and also has a reputation of an ultra reliable HDMI implementation which seems to be lacking elsewhere, and is why I have stayed away from HDMI audio so far.
If I sell off my two current pre-pros, the cost of the Marantz and the ADA will be only a little more than the cost of the Ayre alone.
Anyway, that's all off in the future. the Marantz won't be here for a while. I'll report back when it is.
post #112 of 207
I am extremely happy with my Marantz sonically but have a question about a glitch I am experiencing. On SACD my first player sometimes gave intermittent sound. I was clearly a defect and I send it back and got a replacement. The 2nd player was working fine for 2 months and than had the same problem. I switched off "source direct" and the problem went away. When I switched back to "source direct on" the problem had disappeared. Now in my third month of ownership it happened to me once again. Thankfully, the fix is extremely easy, but still this is a technical issue that Marantz can hopefully resolve in firmware. When my first player acted up I called Marantz they said they never heard of the problem. Any other Marantz owners that have experienced the same problem?
post #113 of 207
I've had no such issue.
I luv this player!
post #114 of 207
When My UD9004 arrives, will I be able to use my subwoofer with the 2ch analog (balanced) outputs, without converting the signal to digital?
My fronts are less than full range.
post #115 of 207
No.
Edorr and I both use PS Audio PerfectWave Transport and DAC for our two channel - except that we use the UD9004 for stereo SACD (and multichannel SACD and DVD-A).
post #116 of 207
Seriously? Major bummer, there. I think there's maybe a way to do that with my P7 though...at least I know I'm doing it now with the 5910.
post #117 of 207
This is how I understand it works. The crossover works in the digital domain, but since you are playing the disc on the Marantz bass management happens in the DSP of the Marantz before anything gets converted to analog. The DSP works with a PCM signal so for CD you are not losing anything and there no additional conversions.
For 2 channel SACD the Marantz needs to convert DSD to PCM before you can use the DSP and hence your sub. I would expect this all happens in the digital domain before anything gets converted to analog, so what you lose here is the DSD to PCM conversion (which is substantial in my experience), but there is no additional A/D/A conversion.
I personally would typically prefer 2 channel SACD without the crossover, and CD with the crossover.
I believe all outputs are active all the time, so you should be able to combine the 2 channel balanced outs with RCA out for the LFE channel. Although Steve and I both use the PWD, the Marantz is a very competent 2 channel player, especially balanced.
post #118 of 207
Thanks Edorr. I'll just have to play with it. I think I can send full range 2ch analog to the P7 and cross it over there to the sub. Have to read the darn manual, I guess.
I know I'm able to play 2channel plus sub with my 5910 + P7 combo now, so I expect I'll be able to figure out a way to do it with the Marantz. Where it gets crossed over remains to be seen.
Probably best to do it digitally in the player before the D/A conversion, but after it at the Halo is OK too. I just don't want a lot of back and forth conversions.
post #119 of 207
Just checked the P7 manual, and there is an option to use the subwoofer with any of the stereo in/outs--including balanced. The two channels are summed, and then routed through a low-pass crossover to the sub channel. I thought that was the case, but nice to confirm it. There is also a high pass for the mains, and the sub trim level can be set individually for stereo and multichannel sources.
I'll be able to compare that to crossing over in the marantz, hopefully soon!
post #120 of 207
The P7 will do the trick in the analog domain. I have a McCormack MAP1 MC analog pre in my secondary system that synthesizes full surround from 2 channel source, all in the analog domain. Works like a charm. You can also get your bass crossed over in the Marantz, in the digital domain before anything is converted to analog. The advantage of doing it in the P7 is you can use your sub on 2 channel SACD sources without having to convert DSD to PCM. Let your ears be the judge.
