Originally Posted by penngray
You can separate the two.....measurement/science will give you a very good idea if a speaker is good or not. measurements should also give you an idea about how the speakers sound. This again is a hypothetical point because we all know many measurements are not accurate or they just are not done.
As for people wanting an accurate or inaccurate sound that should have little to do with speaker purchases...HONESTLY people shoulld buy speakers based on how well they are built, how well they measure, how much they cost (budget concerns) and how few flaws their sound has. Once the right purchase is made people should take that scientifically accurate/well built speaker into their room and EQ it to the sound they want!
Chasing a specific sounding speaker (inaccurate/distorted response) only to have it change in our rooms because of Audyssey, in room problems, System setup issues, etc makes me wonder daily how much people honestly do not care about the science and constantly convince themselves they are hearing something no matter what room the speakers are in.
More to the point, you do not find a speaker with more bass, you EQ your system to give you more bass...do you understand that? If you did choose well build/accurate speakers this is much easier to do....5 years down the road your preferences change, you do not buy new speakers you once again EQ to your current needs.
Most people don't care about how a system measures. Frankly I don't care how a system measures. Take any of your favourite albums. Are you listening to the music or listening to the recording? What the measurement brings is the the flexability of the sound system to sound good for a variety of recordings.
Say for example I only listened to solo violin recordings. So I built a speaker inside a Strad. Then every recording I heard sounded like it came from a Strad. Is that not the most ass kicking speaker? How crappy would it measure? The manufacturers mold and react to what the market demands. It would be a travesty if we were forced to purchase "flat" speakers.
To seriously answer your orignal question I need to modify it.
What part of musical sound is not measureable?
Toe-tapping factor
Head banging factor
Emotion
Passion
What part of movie sound is not measureable?
Excitement
"I was there" factor
Certainly if your amp and speaker and room are really bad any part of these elements is lost and on a nice system they are enhanced. When I look at a brochure for a new amp this is what I'ld like to see.
