AnandTech's In-Depth Power Supply Review
If you're planning on building a HTPC or a high end desktop PC, info about the right power supply can be hard to find. It's easy to find hundreds of in-depth reviews on the latest CPU or Video Card but rarely do power supplies get the same in depth treatment. Anantech has a valuable article for people looking for concrete info about how much power you might need and a detailed comparison of 20 available PSU's in the 300W-450W range and a comparison of 12 in the higher 500W to 550W range.
You'll find some links to the reviews as in the Hot Stories section at HomeToys.com
