AVS › AVS Forum › Video Components › Home Theater Computers › TotalMedia Theatre 3 Platinum
post #1 of 3406
http://www.arcsoft.com/public/softwa...nt=LANG_DETAIL
More info now on Arcsofts website. Priced at 79.95 . Supports HDMI 1.3a with compatible hardware?
Wonder when we get the "Buy" button?
post #2 of 3406
It does not seem to offer much over version 3.
Perhaps this one will give us 1080p/24 output that actually works.
post #3 of 3406
From the Features website:
< snip >
  • DMI 1.3 pass-through support, for lossless 7.1 channel audio output through receivers*
*ASUS Xonar HDAV series audio card required.
< snip >
Does this mean it supports bitstreaming through the XONAR card, i.e. the ASUS OEM software is no longer the only one that works with this card?
Would this also include HD-DVD?
____
Axel
post #4 of 3406
Looks like it. The Xonar support was implemented by Arcsoft (with the work being partially funded by Asus). It's not too surprising that they now merge this into their own retail product.
Well, let's first see if HD DVD is supported at all. If it's not, that's an instant "no sale" as far as I'm concerned.
For completeness' sake the other features marked as "new":
- Enhanced Blu-ray interactive features, including BD Profile 1.0, Bonus View and BD-Live [ weren't those already supported by version 2?]
- Direct playback from high-definition Camcorder
- Experience surround sound with two-channel output devices such as speakers
- Advanced video features such as HQV support, and Auto Enhance
- Popular internet HD video support – MKV
Looks a bit underwhelming to me. If the video quality is really improved as the second but last bullet seems to imply, that might be a reason to upgrade.
post #5 of 3406
I would be really nice, if this version also ran on Win7 (beta).
____
Axel
post #6 of 3406
The single biggest thing is that this should support Windows Media Center integration with bitstreaming. That is huge!
post #7 of 3406
Cool keep the InFo coming
Mucho Gracias to all !
post #8 of 3406
1080p24 has worked for me for a long time. Vista x64, NVidia 9800GX2.
post #9 of 3406
Huge? For the 11 people that own an HDAV maybe
post #10 of 3406
The site page says:
For HD DVD and Blu-ray, TotalMedia Theatre fully supports the entire specifications and can play back:
Blu-ray movies (BDMV, BD Live), including all Hollywood movie discs, with full support for Java games and Internet interactivity
HD DVD movies, including full support for user interaction and Internet interactivity through HDi
Personal recorded BD-R/RE discs (BDAV)
post #11 of 3406
I wouldn't doubt if this was just a second leak of the product info.
There is no PR http://www.arcsoft.com/public/press_list.asp about the product and it's a different page then we saw back in januarary.
Also there is ALOT less HD-DVD, including the removal of the HD-DVD on the main page verus last time it leaked when it was still prominent.
post #12 of 3406
What exactly does "Advanced video features such as HQV support, and Auto Enhance" HQV is a test I thought. Do they mean that they're including some kind of upscaling ala pdvd9
post #13 of 3406
post #14 of 3406
I dont see a buy button.....I'll be buying this when available.
post #15 of 3406
CUDA Only?!
post #16 of 3406
If they managed to get the keyboard shortcuts working for BD-J discs, then they might have a product worth buying...
post #17 of 3406
When can you buy it?
post #18 of 3406
Jason said sometime between now and late Monday night PST. So, I guess keep checking. Also, there will be a trial but it will not include Dolby support. (Beats me...I guess Dolby said no according to what Jason posted). I asked about HD DVD support and he said it should work the same as TMT 2. There should also be some upgrade pricing, as well, but I don't know the details of that yet. All in all this is a must buy for me as TMT is my favorite player software at this time.
post #19 of 3406
Oh, P.S. This is supposed to work with Windows 7, as well. I didn't get a reply about the Cat 9.x drivers yet, though.
post #20 of 3406
Anyone use the VMC integration on it before?
I have the OEM version so mine doesn't have it and am considering upgrading to TMT 3. Do you get box art like media portal on VMC and then just choose your MKV or blu-ray ISO to play? Does it automount ISO?
post #21 of 3406
hi, 24p works for me.
I use reclock and lock it at 24p.
CaM
post #22 of 3406
It would be nice if Arcsoft_Jason could post in this thread about availibility and new features.
post #23 of 3406
He said it will support HD-DVD, but in the current way it is supported (on Ver 2). In other words, do not ever expect bitstreaming for HD-DVD. That is understandable.
It will play them, though.
Right now, he is elbows and ******* deep in putting up the trial version...finishing the QA testing, etc. At least he was as of late Friday night. I would not expect to hear from him for a few days.
post #24 of 3406
I agree that it's acceptable for HD DVD not to bitstream. The fact that they're keeping support for it at all makes this a must buy for me the moment it's available. By far my favorite player on the market.
post #25 of 3406
Agreed. "Unofficial" support on the existing level is just fine. If this turns out to be the case, I will buy the upgrade just to reward them for not leaving some of their customers high and dry without any good reason (and to fart in Cyberlink's general direction ).
post #26 of 3406
Does that mean it will decode DD+ and TrueHD fully and output as multi channel (if applicable) LPCM over HDMI like all HD DVD STB's? If so that is acceptable, if it will only outputs lossy over S/PDIF then that's not.
post #27 of 3406
TMT2 does that now. I play my HD DVD's using TMT2 and output LPCM over HDMI using my ATI. What it means, however, is that the sound is downsampled. Which isn't nearly as bad as outputting over S/PDIF, but, understand that you'll get 48/16 when it downsamples the audio.
post #28 of 3406
Hope they removed the "feature" that causes TMT to shutdown if Visual Studio is used.
post #29 of 3406
Oh ouch. Hadn't seen that issue but I haven't installed VS on my machine in a while, either.
post #30 of 3406
I doubt it. It's probably part of the Themida protection system used by TMT to shut the software down when it detects a debugger running. While this is not nice, it is another case where the AACS license agreement forces them to make some efforts to prevent tampering and reverse engineering (extraction of AACS keys etc.). Since I don't use my HTPC for development, it doesn't bother me so much personally, but I can certainly understand that it does inconvenience others.
