AVS › AVS Forum › Video Components › DVD Players (Standard Def) › "upconvert" DVD player giving terrible picture - please help
post #1 of 5
Hi - been very happy with my 42" Panasonic (720p) TH-42PX80U, plugged into HDMI to a cable box. HD pictures are fantastic.
However, i just bought a Sony Sony DVP NS700H/B "upconvert" DVD player with tons of great reviews on all sites. It's plugged directly into the TV with an HDMI cable.
I wasn't expecting perfect quality, but based on the reviews i thought the picture would be very good. However, it's terrible. Grainy, bitmapped/blurry around the edges, etc. Dark Knight, which i figured was about as good production value you can get, looks horrible.
I tried other HDMI cables, various DVD player settings (eg setting it down to 780p), etc and nothing makes any difference.
Could i have a lemon DVD player? other ideas?
thank you for your help
post #2 of 5
Get a calibration disc and properly set up the display. Turn off any and all picture enhancements in the player and set it to output 720p.
post #3 of 5
RG rime is right. The calibration must be off if you have tried various players. I have 720 Samsung abd the Toshiba XD-E500 looks better than broadcast HD(mind the artifacts that go away once you foll the story line.).
post #4 of 5
Did you mean 480p? Did you try component cables instead of HDMI?
post #5 of 5
Try either 480p or 1080p - I'd expect 1080p will give you best results - internal scaler is 1080p and not of the best quality, de-interlacing isn't good either.
  Back to Forum: DVD Players (Standard Def)
