Originally Posted by sspears
Can you double check the red on yellow stripe and see how it looks? Sometimes the diamonds may look a little thicker on one side or the other because of the pixel layout in the display. The red should make this clear. If one side is dark and the other light, then there is delay. If both have the same lightness/darkness, you are OK.
Next time we will include a version of the pattern with error in both directions so you can compare.
OK, I assume you mean the thick red box in the yellow background. It seems to be the same as I see best looking against the gray background (lower left).
On the red-on-yellow, red seems to bleed 2 pixels to the right of the vertical sides and less so on the left side.
On the red-on-gray, it's easier to see. Red feathers out into the gray 2 pixels on the right side and 1 pixel on the left. Best seen with the patterns 3-4 pixels wide. All of this is only visible up close to the screen.
