AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › "High Definition Benchmark" BD Edition by Stacey Spears and Don Munsil
"High Definition Benchmark" BD Edition by Stacey Spears and Don Munsil - Page 36
post #1051 of 1159
Based on your previous comment about the green looking like the lower right, it sounds a lot like 601 color conversion error. Do you know anyone with a VP50Pro you can borrow and try out?
post #1052 of 1159
Originally Posted by gtm73 View Post
Kris:
That is the first thing I tried, and it does indeed work to reduce the clipping in red. However, the reduction in contrast signficantly impacts the white and black levels. When I go and watch actual content the impact of the reduced contrast in white black levels is far more noticable. I don't really notice the red clipping causing a funny issue with content...
I was hoping to adjust something else to keep white and black set "right" and resolve the red clipping issue with another setting...
Did you recalibrate black level after reducing contrast?
larry
post #1053 of 1159
Larry:
Thanks for suggesting both of these things again. Apparently I just wasn't patient (i.e. smart) enough the first time around. I have gone back and found that I can turn Contrast down significantly (solving the red clipping issue) and that didn't impact the whites.
Stacey:
Having googled VP50 I can confirm I don't have one at my finger tips :-) I could probably hit up a guy I know at a high end shop. Since I can get the red squares to show up with a reduction in contrast would you still have the 601 issue in mind?
post #1054 of 1159
Larry:
Good news!
larry
post #1055 of 1159
Red and blue should clip around the same time. If you have to turn down contrast a lot between blue and red clipping, then its worth trying to get a VP50Pro to at least test with, otherwise you are turning contrast down too far.
post #1056 of 1159
Hello Folks, I've ordered the disk from amazon UK but still waiting for it to arrive. My goodness you guys are much more technical than me I hope that I can use it.
Steve
post #1057 of 1159
My disc gets frozen on the HD Color Bars/Sharpness area of the disc.
The BD is pristine. My player is a Pansaonic DMP-BD65.
I end up ejecting the disc and restarting to get beyond this point.
Has anyone else experienced this or have any ideas?
Thank you for your time.
post #1058 of 1159
For grins and giggles, use some warm water and mild soap and wash the BD face and see what happens. Can't hurt and sometimes it works.
larry
post #1059 of 1159
What do you mean it gets stuck? Once you start playing the pattern, you can't go back to the menu?
post #1060 of 1159
What I mean, is I can hear the laser clicking, like it can't find the next track mark. The time shows all zeros, and if I push up arrow to show the help function, or the right arrow, track forward or pause, nothing happens. The only player function that seems to work is eject.
I have no other issues with this player with about 100 other BD's, so I don't think it's the player...
post #1061 of 1159
Also, the disc goes from the jewel case to the tray and back again. That's all...I treat my S&M BD With the Love and respect it deserves! :-)
post #1062 of 1159
Sent you a PM.
post #1063 of 1159
Testing frame-rate errors
Some receivers are known to have the 24.00 fps bug, in that 23.976 fps input source is output as 24.00 fps, and 59.94 as 60.00 fps. The latest culprit is the Onkyo TX-NR818. Some users have noticed it but not others. Until recently I confirmed it using a DVDO Edge to 'measure' the AVR's HDMI video output it remained only a suspicion that this is happening. In the discussion in the Onkyo thread we note no reviewer has found this bug and that very few devices can distinguish between 23.976 and 24.00 fps on their GUI info display and this isn't something that reviewers normally would measure.
I wonder if it's possible to devise some test patterns that more people can use to look out for this bug and this may be more common occurrence or more disturbing to some than the odd cadence de-interlacing issues which reviewers seem keen to test on players.
post #1064 of 1159
^ I think any sort of scrolling pattern should show that frame rate issue fairly clearly (if you don't happen to blink).
http://forums.roku.com/viewtopic.php?p=306931&sid=520e408816b213ce5ada4600683f04d4
post #1065 of 1159
We have a stock ticker type clip on the upcoming disc that may help. We offer it at 24p (23.976), 30p (29.97), and 60i (59.94 fields per second).
post #1066 of 1159
Is there material on this disc that will help show if you have colour uniformity problems? I have a plasma with green/yellow blob in the middle and pink tinting issues on the sides. Usually most visible in grey, white and beige scenes. I don't always see it but I want to see if changing my calibration will change the blob/tinting to any degree.
Can I do any grey-scale calibrating at all without a colour measuring tool?
post #1067 of 1159
The 2nd edition does have a couple of uniformity patterns. Solid white field, black field, and then both with inverted squares in locations you should measure with a meter.
You can set the basic user level control that has options like cool, warm, etc... To adjust the bias and gains you need a meter or at a minimum, a gray card with D65 reference light, which I would not recommend even trying.
post #1068 of 1159
Here is what the case will look like.
It will not make it out this year since it is still in authoring. Once we sign off on a build of the disc, it will take around 20-days to replicate. 5-10 to get the check disc back and another 5-10 once we give a thumbs up to the check disc.
post #1069 of 1159
I want to just say that I'm super excited about this new disc, and I'm looking forward to hearing what people think about it. We managed to do some things people said couldn't be done with 4:2:0, like smooth single-channel (RGB) ramps that hit every level on the nose, and perfect monotonicity patterns. We rethought just about every pattern on the disc; almost nothing is just carried over intact. There are tweaks and adjustments all over. In addition to tweaking all the old patterns, there are literally hundreds of new clips and tests. And we think this may be the first commercial disc with stereoscopic test patterns on it, as well as a complete set of standard patterns encoded in 3D so you can do standard calibration while your display is in 3D mode.
Don
post #1070 of 1159
^^^^ Cool, can't wait for the new disc!
larry
post #1071 of 1159
We spoke with authoring today and we are targeting the end of January to be finished. If we hit this date, then the disc should be available in March.
We have also decided to create a scaled down version for DVD. At this time we are not sure if the disc will be bundled with the Blu-ray or a free download.
post #1072 of 1159
What do you expect the retail price to be?
post #1073 of 1159
That's a great question! We don't know the cost of materials yet. For example, the included booklet is longer. It should be priced similar to the original disc.
post #1074 of 1159
Hi,
Trying to get a copy of this DVD!
Any update on the release date?
And where are the first available copies going to be released from?....in terms of what retailer?
post #1075 of 1159
We approved the Blu-ray check disc on Friday. We hope to have inventory in three weeks.
It will go on sale at OPPO and Amazon first. If another retailer wishes to sell it, they simply need to contact us.
post #1076 of 1159
Is Amazon going to do a preorder listing ?
post #1077 of 1159
Hi Stacey - what is up with the pricing for the out of print disc? Zounds!
http://www.amazon.com/gp/offer-listing/B001UM29OC/ref=dp_olp_new?ie=UTF8&condition=new
post #1078 of 1159
It probably won't go on Amazon until it is in stock.
When the 2nd edition comes out, the prices on the 1st edition should drop.
post #1079 of 1159
Will you update this thread once it's available, or should we just check Amazon?
post #1080 of 1159
We will post. We are also launching a new website soon. Target is 4/22.
  Back to Forum: Blu-ray Software
