Thank you so much for your quick replay!
Me too, I read that VT50 has a best performance with 4:4:4. But, in this case, I have to set 4:4:4 on Radiance output configuration?
If Radiance is configured in 4:4:4 to VT50, It's ok set the sources in input to Radiance in 4:2:2? In general my sources are in 4:4:4 and I can't change this parameter (only on my bdp I can)...
And about dither? It's ok if I set 10 bit on radiance? Is this setting the best to VT50?
Thank you so much for your explanations and for your help
Vincenzo
Vincenzo
