Originally Posted by dmunsil
The two reasons I can think of offhand for that background checkerboard to get more visible would be:
A. Brightness is different in the two color spaces. It would be worth re-running the brightness adjustment to make sure the display is not clipping the below-black and elevating the black level at the same time. Obscure, but possible.
B. Gamma is different between the two color spaces. That's the more likely case, perhaps. It might only be different near black. Ultimately if the checkerboard is highly visible, that's probably a deviation from the conventional gamma. On a BVM the checkerboard is just barely visible. But gamma isn't actually standardized; the best yardstick we have is what things look like on a BVM.
So the bottom line is that if everything else looks good, and the calibrations for the other settings didn't change, pick whichever one looks good to you. Myself, I might lean toward the darker setting where it's harder to see, but I can't see what you're seeing, so go with your gut.
Wow, Thanks Don for the quick responce. I took another look at it last night.
In RGB there is no difference in the rest of the settings. Brightness, Contrast, Sharpness and colour is all the same. The checkerboard is sooooo clear in RGB that I even noticed that the left hand side checker is slightly brighter than the right. Switching to Y,Cr,Cb 4.4.4 had the same brightness it just looked fuzzier. Interestingly when I switch my projectors Colourspace setting to only take RGB the colour setting is still available to adjust. Doesn't this mean that the projector is taking the RGB source converting to Y,Cr,Cb and then re-converting back to RGB. Maybe this extra processing is sharpening the signal up???
I will go with my gut. I threw on several low light scenes last night and I have never seen so much detail before. Bright and mid level scenes seem a little less blury, more refinded also.
I really like it. It has been a great discovery.
Sorry for asking. What is BVM?
Ta Dono
