Originally Posted by dbmix
this purports to allow SATA devices to operate with IDE ATA controllers.
http://www.newegg.com/Product/Produc...82E16812206001
or this?
http://www.newegg.com/Product/Produc...82E16812339152
or this?
I know someone who has tried to use SATA to PATA converters in a RTV 50/55xx box - No go.
If you go this route, prepare to buy, try, and RMA until you find one that works. Again, the RTV's IDE controller is like Morris the Cat, and only likes certain things, standards be damned.
I have read reports that ANY WD drive with 'AA' is no-go in a 50/55xx RTV, no matter if it's JB, KB, oer anything else.
newegg had some 80 GB non-AA JB drives in stock last time I looked.... Yes, small, but you will be hard pressed to find anything larger that 160 GB that will work in a ReplayTV 50/55xx box nowadays.
If the refurbished 400 GB Seagate is a 7200.8, then it should work, provided they didn't change out any firmware when they refurbed it (and making it a .9 or .10 -- which don't work.)
Good luck!
-Doug
Silly me! Anyone want a shiny new WD paperweight? Seriously, I tried a WD5000AVJB & no go. Worked fine in PC (wrote zeros to drive & installed software & all looked ok) but could only get "Please Wait" screen. Has anyone tried a Maxtor STM3320820A? It's listed on the Seagate website.
