Originally Posted by JJHXBR
I installed firmware version 1.7 and it seems to have fixed a minor issue I was having with my BD80.
Using the 7.1 analog connections with the HDMI audio turned off, I was getting a on screen "unsupported audio" message between layer changes while playing certain blu-ray movies.
This didn't affect performance in any way, but was very annoying to say the least.
Turning the HDMI audio on also seemed to fix the problem, but you shouldn't have to have HDMI audio turned on, if you are only using the 7.1/5.1 analog connections.
The last 4 movies I have played after installing firmware version 1.7, have had NO "unsupported audio" messages with the HDMI audio turned off.
Have had no more freezing incidents, and have only had two prior cases out of about 100 blu-ray movies.
So far so good, and hopefully will stay this way.
Has anybody else who owns a BD80 using the 7.1/5.1 analog connections, experienced this "unsupported audio" message at all?
I have been using 5.1/2.0 mode with fw 1.5 and have never seen this message.
(and for putting up with those who wonder what a VCR is....not on these forums, tho, BTW...)
