i have the usual complaint: i need two remotes because the ps3 MUST USE BLUETOOTH!!! so i thought about what it would be like to eliminate ALL my remotes and find a smartphone that has both IR and bluetooth capabilities (not too hard to find, but it will be hard to find one with strong IR signal. if you know of one, lemme know), find programs that will run the smartphone as a universal remote and use it with this program to just use my smartphone with EVERYTHING!
if anybody has any other suggestions or how-tos, lemme know. this is probably the cheapest and best solution that i can think of to fix this problem... for the time being. i know logitech came out with a fancy dongle, but i don't want to have to plug ANYTHING ELSE into my ps3 which only has two USB ports anyway.
i figured this would be a good discussion topic, input is welcome
