AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › Is this vertical banding ?
post #1 of 3
I have a Panny AX200 great great pic ....
The unit has bout 6 months of use on it .Turn it on today to watch College Basketball notice a green stripe on the right side of my screen.. I change the channel same results, change hdmi cable same results .. I have the unit hook up to my comcast hdtv box .... I only get the green stripe when I'm watching TV i have unplug my cable and replug it back in same results .. What could be causing this ?? Thanks for any and all help
Mr.Cinema
post #2 of 3
I figure out the problem it was the cable box .. had to go into service menu and change the output signal ...
post #3 of 3
yes right may be the cable box have some problem you should check it patiently
and if you can't resolve it you should ask the engineer
