AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › SVS PB10-NSD vs SVS 25-31 PCi for Music
post #1 of 7
Hey guys, wanna get a real nice sub for 75% music, 25% movies.
My room is about 13x14x13
I really just want the most musical sub out of the 2
post #2 of 7
I would lean towards the 25-31 for 75% music. Even so, I don't see a big difference between the 2 (for music).
For HT the PB-10 is flat to 19Hz which gives it an advantage over the 25-31.
post #3 of 7
Thanks for the reply, couple questions...
What things would make you lean towards the 25-31? Is it because its a 12" instead of a 12"? Would it have just as good or better articulation, speed, and sound quality?
I'm a little skeptical of the 25-31 because it's a cylinder and I've never heard one. Also, I didn't find a measurement chart for the 25-31. The PB10 can go flat to 19hz, how low can the 25-31 go?
post #4 of 7
I too am deciding between the PB10 and 25-31. Based on the votes, it looks like I'm going to get the PB10-NSD!
Thanks everyone
post #5 of 7
The 25 in 25-31 states the tuning frequency. It is tuned to 25Hz and you'll probably get 22Hz in room. The sound of the cylinder is not a concern. It is just a round box. Because of it's shape, they can make it much lighter than a box. For your use, I think I would still go with the PB10 as it has pr oven to be an overachiever. I believe the driver is based more on the Plus than the NSD.
post #6 of 7
Hey all,
The closeout 25-31 PCi is custom-tuned at the shop to 22Hz, so figure 20Hz or so extension in-room.
post #7 of 7
Hmm, tied votes...
I still think I would go with the PB10...
I feel like the 25-31 would be too powerful for the room size, then again I guess you could always turn down the gain/volume... I just like the look of the front firing box subs more than the cylinder ones I guess.
