AVS › AVS Forum › Video Components › Home Theater Computers › How to get digital output from my computer?? Gateway DX4640, Vista 64bit, Realtek.
post #1 of 5
Hey guys,
I just bought my first Media Center PC, HTPC. It is a Gateway DX4640-UBC01A0 w/TV tuner and HDMI output.
Everything works fine, and I'm getting used to working with a HTPC, as opposed to using cable or directv.
Anyway, my problem is I received the computer, but I can't get my digital output to work. I have a Realtek sound card with Integrated 8-Channel (7.1) High Definition Audio.
This digital audio is output via 1/8" phone jacks. Anywone have these their HTPC?
I hooked my HDTV output to my plasma, and the 1/8" digital output for L/R to my PeachTree Audio Decco Integrated Amplifier.
Anyway, when I go into Vista and enable the digital output, I get nothing. Anyone have any pointers on how to get my digital output working?
When I run the test in Vista, I see the volume bars moving, but I hear nothing through the speakers. Am I missing something?
Do I need a new sound card?
Thanks in advance.
post #2 of 5
You mean Toslink?
Have you messed with the Realtek control panel?
I'm using Coaxial on mine, but I'm not using Realtek's drivers, as I couldn't get them to support 7.1, but the default Vista drivers did it just fine
post #3 of 5
Originally Posted by EGOvoruhk View Post
You mean Toslink?
No I mean spdif out via 1/8". Well actually the connector on the back of the computer is 1/8" terminated. The manual says this a spdif output. It loos like a headphone/microphone 1/8" input. So have a toslink cable going to my integrated amp, w/the end connected to the computer using a toslink to 1/8" adapter.
I have messed w/ the Control Panel nothing worked. I have not messed drivers yet though, didn't want screw anything up.
post #4 of 5
More specs on my computer. It has:
  • Intel Intel® Core2 Duo Processor E4700
  • NVIDIA® GeForce® 7100 chipset
  • MSI NVIDIA MCP73PV Motherboard
  • NVIDIA GeForce 7100 integrated graphics
  • Integrated 8-Channel (7.1) High Definition Audio
  • Controlled by Realtek ALC888S which supports
  • 7.1 channels audio out# Compliant with Azalia Spec, there is an internal connection on the motherboard for # Two SPDIF-Out connectors
So I know it supports 7.1 output via the back 1/8" connectors. Problem is, I'm not sure if it supports digital output (7.1) via the 1.8" rear connector (1/8" side speaker output, which is label spdif in the manual.)
post #5 of 5
I might be wrong, but I'm pretty sure that you need a spdif out bracket/adapter that attaches to the spdif out pins on your motherboard. The problem is finding one. I would try your mobo manufacturer's site first or google on how to make one. googling "spdif out adapter" gives hundreds of hits of folks looking for these things. I think most end up getting a cheap sound card.
BB
