AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Lag results - Samsung A750 vs B650 - Also my Opinion on them both compared
Lag results - Samsung A750 vs B650 - Also my Opinion on them both compared - Page 2
post #31 of 136
Did you retest the VGA mode at all? That is my primary concern since it's how I'll be hooking up my Xbox. At least, I think it is. My 360 is old and doesn't have HDMI so it's either component or VGA.
post #32 of 136
Well at the very least PC mode looks better than the a series PC mode by what this guy says so using VGA will mean it won't look like crap so that should help you out a bit. Ironically people who use the VGA on the a series TVs don't complain the picture looks like crap though compared to people with HDMI and switch between PC mode and non-PC mode. Probably because one can compare the 2 so maybe that's why but still some have said VGA seems less washed out than HDMI2/PC mode so who knows.
post #33 of 136
Originally Posted by KVW View Post
OK I just tested the B650 against the A750, both in GAME mode by changing it in the "setup" in their respective menus. I power cycled them both to be sure the bug mentioned above wasn't happening.
Surprisingly they are just about dead even with only a slightest advantage to which monitor is set to be primary. However on in their respective PC modes, it didn't change the outcome. The A750 still had at least a frame lead.
I actually think Samsung just made a change to PC mode by leaving some video processing on as they probably got complaints that PC mode on the A series washes everything out. There's definitely a PQ difference between the B650's PC mode and the A750s. The B650 looks far better in PC mode. Since it was never Samsung's intention to have PC mode as a solution to reduce lag further from Game mode, this is probably their "Fix" for the poor PQ in PC Mode of the A series.
So is game mode enough for most people? Probably. But remember Game mode on a Samsung is at least a frame behind A750's PC mode. And the A750's PC mode is at least a frame behind an LZ800. And a LZ800 is damn fast, but it is NOT as fast as a CRT (it has some lag of course).
My suspicion is Samsung's Game mode would be around 40-60ms (3-4 frames) when compared to a CRT. It makes a difference still as it's alot better than when not on Game mode! I actually find it to be a chore to navigate the mouse when in Standard mode! That goes for the A750, B650, the Sony Z4100, the Mitsu 40148, every display that's 120hz beside the toshiba. But would it affect you with timing sensitive games? I think so. Those who love fighting games usually will be the first to feel it, next is competitive only shooters.
If anyone else has any suggestions let me know.
So basically when comparing Samsung B650 VGA or either PC MODE it is at least faster than the Samsung A750 Game Mode???
post #34 of 136
Originally Posted by felonyr301 View Post
Well at the very least PC mode looks better than the a series PC mode by what this guy says so using VGA will mean it won't look like crap so that should help you out a bit. Ironically people who use the VGA on the a series TVs don't complain the picture looks like crap though.
VGA does look better on the b series as well. Like I said, I getting the impression Samsung decided to fix that by not removing as much image processing. I guess they didn't take in account that a small minority was actually using those modes to achive even less lag.
I'll test VGA again now.
No. Just game mode vs game mode, they are the same. B650 game mode & PC mode still lags behind a750's PC mode.
post #35 of 136
May I also ask what options are available when in Game Mode with the B650 TV?
Since Game Mode on the A750 definitely has dynamic contrast and edge enhancement on I would like to know if those two options are available to be used under Game Mode in the B650 TV.
I'm just asking because that could also make a difference in comparing both Game Modes.
This is also why I believe Game Mode in the A750 could of been faster possibly similar to HDMI2/PC mode if it didn't have dynamic contrast and edge enhancement locked set to on.
post #36 of 136
I know its slower than A750 PC mode but I mean is B650 PC mode faster than A750 Game Mode.
Yea I also figured that about the improvement of picture quality in PC mode on the B650 when you said it is improved from the A series.
Like I said it was never meant for reduced lag purposes like Game Mode it was meant for PC use specifically to make text look correct as it can be.
EDIT= Ohh I see you meant they are the same Game Mode and PC mode for the B650 ok I get it...
post #37 of 136
Newbie questions,
If I'm simply just watching TV, movies, and occasional PS3 Plyaing baseball, soccer, basketball, does this LAG even matter?
I ask because this thread is starting to scare me in terms of getting the B model over A.
post #38 of 136
Game mode on the B650 gives you:
Backlight (adjustable)
Contrast (adjustable)
Brightness (adjustable)
Sharpness (adjustable)
Color (adjustable)
Tint (adjustable)
Advanced settings:
Black Tone (adjustable)
Dynamic Contrast: (adjustable)
Gamma (adjustable)
Color Space (adjustable)
White Balance (adjustable)
Flesh Tone (adjustable)
Edge Enhancement (adjustable)
Picture Options:
Color Tone (adjustable)
Size (adjustable)
Digital NR (adjustable)
HDMI Black Level (adjustable)
Film Mode (OFF - Grayed out)
Blue Only Mode (adjustable)
Auto Motion Plus (OFF -Grayed out)
post #39 of 136
Originally Posted by Guitar Maker View Post
Newbie questions,
Watching movies, TV, not at all. Occasional Ps3 sports games, in game mode for both the A and B, they are the same and you'll be fine.
It's only the picky few or those who take Fighting games or competitive First person shooters too seriously that it affects. If this isnt you, nothing to worry bout, get the B for sure, better PQ.
post #40 of 136
Whoa don't confuse input lag with response time buddy; a high input lag of 100-200ms won't affect people who just watch videos/movies.
Input lag is controller lag like when you press a button and it takes a 1/5th of a second to be displayed on the TV.
It has already been said that 30-60ms of input lag is not noticeable for like majority of people and in depending on the game also.
Usually its with fighting games first then first person shooters while playing online which is never 0 ping is where 60ms of input lag could affect some and the keyword here is some.
post #41 of 136
Color (adjustable)
Tint (adjustable)
Advanced settings:
Gamma (adjustable)
Picture Options:
Size (adjustable)
So damn all of those is available now heres one of my last questions;
when comparing Game Mode on the B650 vs A750 did you turn ON Dynamic Contrast and Edge Enhancement???
Common sense would let me to believe that turning off those 2 options should make game mode faster than A750 Game Mode since those are locked set to ON on the A750.
post #42 of 136
on the B650 in game mode, edge enhancement was on but not dynamic contrast ratio. On the A750, it doesn't even show edge enhancement as an option (advanced settings disappears) so I don't know if it's on or off.
I can retest game vs game with Edge enhancement off but I am doubtful it will change the outcome. I figure it can fit that adjustment in on pass (one frame) but who knows.
post #43 of 136
No in the A750 Game Mode you can't even go in the advanced settings to even see whats on or not but I know for sure it's on just like Dynamic Contrast (on what level low-high that I'm not sure on). I can tell and there is a game where one can easily tell both of those is on.
Well I believe edge enhancement shouldn't add much or if anything to cry about but dynamic contrast on the other hand could add like an average probably 10ms extra or so.
post #44 of 136
Rather strange to see that the bug initially found on the 2008 A630 series applies to the 2009 B650 series as well. I wonder how many other sets/series it applies to...
I was considering returning my A630 I bought 3 weeks ago (since i'm still in the no questions asked return policy provided by the store I purchased it from), but knowing the only suitable replacement suffers from the same bug and PC mode offering no advantage over game mode kinda kills that whole idea for me. Game mode being adjustable is cool and all, but I don't think it'd be worth the extra effort and cash to replace my set.
I'll just be happy with what i've got.
post #45 of 136
Tested b650 VGA vs the A750 in game mode (b650 has primary monitor advantage). Power cycled the TVs. Again, it looks as though B650's VGA is the same as A750's Game mode. The very slight lead the b650 has, I attribute to the fact that it is the primary display. To restate what I said earlier, the B650's game mode is also the same speed as A750's Game mode. Again, I have a strong belief that all Samsung did now with 09 monitors was fix the poor PQ of 08's VGA and PC modes at the cost of input lag.
post #46 of 136
Side question related to lag: I understand how it impacts gaming, but how about audio-sync? Display lag means the picture will be behind the audio signal, which the receiver likely will be processing/broadcasting before the picture. Now, maybe this is a wash due to speed of light vs. speed of sound, but I'm curious how this plays out. Obviously receivers have delay settings to allow all channels to reach you at the same time, but has anyone ever upped these settings to accommodate display lag?
post #47 of 136
funny you mention that, I dunno if I'm just BECOMING extra sensitive to it because that's all I seem to be doing lately and it's on my mind, or just by knowing there IS lag and now I'm now looking for it... but in standard view, with AMP on in all it's glory, just baaarely... I hear the start of the voice before they open their mouths LOL! My crappy old receiver only allows me to add 15ms delay. I need about 90ms more! Haha!
post #48 of 136
input lag can cause lip sync issues, most notably if your not using the HDMI audio stream coming from the TV, like if you have HDMI plugged directly into the TV and then use Optical digital audio out to a A/V Receiver like I do
if the audio is coming out of the TV or is being fed from the TV to the Receiver the TV SHOULD compensate for the delay, but this is not always the case
newer HDMI receivers have sound delay to correct this problem as well
also as long as the input lag is fairly small its not really an issue, Before i got my Sony 32xbr6 I had a crappy Insignia 32" It had horrible input lag I never tested it at the time because I didnt really know about the problem but i seen it with PC use big time with the mouse and also saw lip sync issues with ANYTHING except for the TV's tuner, this included routing sound though the TV first then to a Receiver!!
now my sony 32xbr6 I have tested for input lag, I thought it was lag free beforehand but it is not, in video modes on any HD input its around 40ms in game mode drops it to about 30ms and SD inputs (svideo was tested) in game mode 40-50 ms never tested svideo out of game mode but its prolly about 10 ms higher.
now i have my PC, PS3 and xb360 plugged into my Receiver directly via optical so I can get DD and DTS sound from movies, and my SD cable box is connected to the TV (composite video, analog audio its a crap STB) and I never see lip sync issues on any input, I think the cable box plugged into composite would be the most likely to cause lip sync issues due to this being the highest lag input on the TV but because i route the sound through my TV then into my Receiver the TV is most likely delaying the sound to compensate for the lag and on other inputs the TV is lag free enough for it to be a non issue
post #49 of 136
could this thread be merged with frito's input lag wars one to make it easier for people to look and compare results like urs kvw?
post #50 of 136
That would be a good idea, though i did already take it upon myself to cross post his test results, er well his first round of them at least
post #51 of 136
Yah the only reason why I posted this in it's own thread is because I thought it was too focused on only two specific panels and the input lag wars thread would get flooded with Samsung b650 v a750 non-lag related questions.
Btw I just tested game vs game with b650's edge enhancement off. Same result - their times are the same with a very slight lead with which ever monitor I set as primary.
I'm wonder if the speed difference is worth it though now... so frickin conflicted. I should flip a damn coin.
post #52 of 136
Unfortunately, I have an older receiver (Denon 3803 that I have no intention of replacing at this time) that doesn't have HDMI. So my TivoHD will be hooked up with HDMI to the TV and optical from the Tivo to the receiver for sound. I know that these TVs have optical out, but from what I understand it strips out 5.1, so this isn't an option. I'll have to take a look at how much delay I can add on top of what it's already set to.
post #53 of 136
Yeah i'm in the same boat, both of my a/v receivers are older ones, I use a Sony in my room with my 32" lcd (its a pc setup mainly and HT/TV secondarily) the sony even has a busted rear surround channel but i dont care much lol ill prolly replace it sooner or later
my other one is a good old Onkyo 777 THX receiver i use with my 46" phillips CRT RPTV 1080i TV, its in our family room and ever sense getting my LCD i never even want to look at that old beast of a RPTV again lol, I live with my sister and her husband so they mainly use it anyways lol
anyways back on topic, yeah pretty much all TV's afaik will downmix a DD signal to DD 2.0 on the optical output, what is interesting though is that when i fed the crappy insignia a DTS signal is just did nothing didn't pass it though or anything no sound on my receiver, My sony actually DOES pass the DTS audio out though Optical untouched for my receiver to decode in 5.1!! course as most things are in DD this is of little impact on the problem lol
still though IMHO MOST TV's are not laggy enough to make it a major problem unless your using Crappy composite inputs on your STB and then Digital audio out to your receiver
post #54 of 136
I found some audio-delay boxes that are available to solve this problem. The cheapest one I've found is the Felston DD740. $250. I've noticed in the past that I'm pretty sensitive for lip-syncing issues, so I may have to pick one of these up.
post #55 of 136
You guys have lag with HDMI to tv and Optical from box to receiver? I'm on my second Samsung DLP and NEVER had any lag connected this way, my receiver is a 4 year old NAD and I never needed to adjust the delay. I find it hard to believe there would be any lag, both out puts from the box are digital (HDMI for video & Optical for sound).. What's even more discouraging is the optical out from the B650/A750 Tvs still does not send 5.1 to your receiver... Why is this?
post #56 of 136
Most LCD's seem to downmix any Dolby Digital signal to stereo Dolby Digital for output on their internal speakers and as a result the optical out is only sending out this signal on HDMI inputs, whats funny is if you use the tuner it outputs full 5.1 Dolby digital. but on HDMI inputs out goes DD stereo
i've yet to find a setting in my sony at least that would change this
post #57 of 136
KVW,
What app are you using to test lag with? Thanks!
post #58 of 136
I downloaded it from here: http://tft.vanity.dk/
But I think there might be better ones out there. This one doesn't move in perfect seqencial steps so have to use some estimating. I think frito updated his orginal post to download a new one in the input lag wars thread. I'll probably use that one from now on...
post #59 of 136
What mode for the 52" a750 would be the best for picture quality and gaming?? I'm not too worried about lag. I got an elite 360 hooked up to my onkyo 876, hdmi takes care of audio and picture. Anyone have any good callibration gaming settings for the A750?
post #60 of 136
Wow seriously depressing thread here ;-) I've been researching hdtvs starting from scratch for about 3 months now & I'd finally narrowed it down to a few models which arent even close to the high end sammys being mentioned here.
sammy LNxxA450
toshiba xxAV502U
sharp LC-xxSB24U
This tv's sole purpose is for my xbox on which i play a lot of Cod free for all. A fast paced FPS as im sure a lot of you know where even the slightest bit of lag as someone else eloquently pointed out about two people coming around the corner at the same time can make the differnce between kill or be killed.
Also like someone else had mentioned I had ventured over to the plasma board because i heard mentions of no response times and other stuff but by the time i got done reading about breaking in, IR, and everything else i had a headache.
Is there any lag test info on some of these older models? Maybe I should just get an lcd for single player games and leave online gaming to my hulking sony crt which still has a pretty decent picture. Any thoughts?
