AVS › AVS Forum › Audio › DIY Speakers and Subs › Re xxx 18
Re xxx 18
post #1 of 9
I just received my RE XXX 18 and I'm looking to tune it LOW as I Have Klipschorns in front. I have built a 17 Cubic Ft bench seat box. I was thinking of using this port design Haliaetus Firebird (revolutionary port design?) from speakerplans.com any input would be great. What freq would be good to tune to, it has a res freq of 15hz a 54 x max It's a monster. John
post #2 of 9
John,
have a look over here:
http://www.avsforum.com/avs-vb/showt...905&highlight=
post #3 of 9
Yep. That's a link to my sub that Dan posted. It's long but there is a lot of good info in there. I wnt with 25cu ft tuned to 11hz powered with a CE4000 (2800w) GL man and enjoy the sub, they are fun. If you have any questions, ask away.
post #4 of 9
You can also copy the material from my build thread (see sig) as it is almost identical to Ricci's XXX18 build. I built two and use Sound Splinter RL18's instead. The alignment is the same so you would get similar if not identical performance from either box. Ricci's looks a whole lot nicer though...
Good luck with that monster!
post #5 of 9
True, but this driver needs some more port area.
post #6 of 9
Definitely. I am sure this big ol' box can fit a much larger port on it though. Hell, this badass mofo could fit a 18 inch diameter port on it if I really wanted too.
post #7 of 9
Time for a retrofit! I think a 12" would be just about right. Then you can use a basketball wrapped in a towel for a port plug.
post #8 of 9
When we were looking at the design, I was looking at a 12" quicktube for a 20hz tune. That alignment looked like it would be flat to 20hz outdoors.
post #9 of 9
any updates rexxx18?
