AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Subwoofer connection question - Will this work?
post #1 of 9
i am about to purchase a second subwoofer, and would like to place it in the rear corner of my living room. i have a speaker wire in the wall, going from the AVR to the rear wall where i "had" a surround rear speaker... so now its just a banana jack wall plate. is there any way or "adapter" that i can get the "rca subwoofer signal" across the regular speaker wire to the subwoofer?
currently seeking a banana jack to rca converter if it even exists...
thanks,
WudChuK
post #2 of 9
You can solder an RCA plug or jack on the speaker cable but that is way less than optimal. Speaker wire is not shielded and there is a very good chance you will pick up noise.
But it is a cheap test so give it a shot if can waste $5.
-Robert
post #3 of 9
-Robert
Does it matter if it is in-wall rated speaker wire, versus non-inwall speaker wire? Or are you referring to shielding more like that on a coax cable?
post #4 of 9
This is an interesting question, and one I have been wondering about myself.
Cable with RCA connectors is shielded cable. I would rather not solder an RCA connector to a paired (unshielded) wire. Nor would I want to strip RCA shielded wire and twist the shielded side for the negative and the core for the positive.
I have about 50 ft of good quality 14 ga. speaker wire running in my walls for back surrounds, which is paired (unshielded) regular speaker wire. I would like to use one of these to experiment with sub placement using the LFE connection from my receiver. I read somewhere that Radio Shack sells banana clip to RCA jumpers, but this isn't something I have ever looked for, so I'm not sure they exist. I see two problems:
1. lack of shielding, which might cause hum.
2. Too much resistance. What does 50 ft. of 14 ga. wire do to the LFE signal?
I suspect neither of these would be a major problem, especially the lack of shielding on the wire in the wall. And to the second concern, 50 ft. of 14 ga. wire would produce a negligible resistive load, but such a heavy gauge, copper wire is also highly conductive (efficient).
Those who have experience with this, please tell me if I'm wrong.
post #5 of 9
so if coax or speaker wire are out of the question, would this be the proper cable i need to run for a subwoofer??
RCA Cable
probably would need a custom 75ft run to get up the wall, across the living room, and back down the wall to a wall jack......
post #6 of 9
You don't want to use speaker wire unless you are using the speaker level connections. If you can find an adapter, you can test, but without a shield you will most likely get 60Hz hum. I tried to find banana-to-rca adapters and couldn't. You can use coax, RG-6 or RG-59, and put RCA connectors on each end. The problem will be getting it in the wall. A 75' run is not a problem.
post #7 of 9
The "LFE cable" I purchased from monoprice is just RG6 with RCA ends on it.
My guess would be that any wire rated to run in-wall for a specific distance to power a speaker would be as well suited to running a sub - assuming the ends could be installed properly.
All I've ever installed on RG6 is snap-n-seal coax ends (when I was a cable guy). The crimper tool was like $50 - the ends are dirt cheap. No clue what a home kit would run you for installing RCA ends - especially if you only need to do it once.
post #8 of 9
Also, for your cable needs, head over to http://www.monoprice.com.
Best site evar.
post #9 of 9
Except that speaker cables are not shielded like RG6 or other proper interconnects.
