ok i think i used you conv matrix and used it as ref followed stereodan inst
ok i did ftl at 10.5 did the grey scale got it close as possible to 2.22 think it became 2.20 with the 2.15 10%
then setup rgb and had to bump up gain r all they way and offset just a little this using 6500k
after that i used the chart that stereo did and could not do the 75% method couldnt get close, but with the 100% i can
once done i saved the picture has nice punch and the 75% i tried to do since i do not have the brightness control was more pale....
so i up the colour temp on 7000k with the 100% method it seemed to tame the colour a bit....
is this the right way i am doing it...
if anyone has any tip for the 1080 non ub without the brightness
would be awsome i think its better than normal....settings.. so i can live with it.
thanx denis
thanx denis
I spent 9 hours last night trying my first calibration. I'm a complete noob. I'm using an i1 LT with a 6500. 200 hrs on bulb. Throw of 19" with 10.5ftl's read with i1 LT(iris off) low lamp, natural setting, on a 92" 1.0 gain screen with some ambient light. I used stereoman dan's excel with the avshd disk and ps3, hcfr software I used the 10% grey scale windows to do gamma and the 90/30 windows to do primary colours. Gamma with the sliders is very hard for me to do. It caused a lot of frustration for me.
I used the 75% saturation windows to do the RBGMCY settings using the excel spreadsheet values with the 100% Y setting used from the cd/m2 box in hcfr. I thought I did quite well at getting the percentage graphs equaled with the proper Y value in all colours. After saving the settings and watching a few minutes of KFP and Star trek I was stunned at how overblown the colours were. Too much red and yellow, it looks terrible. I don't know what the problem is and I really need help. Here are my files.
