the LG has the April firmware in it.....will play BD-R discs but not the BD-RE discs....shows them as data discs.........when i try to record a movie onto the the BD-RE disc my computer says it can't format the disc correctly but allows the ISO to be written to that disc anyway........when i record that same ISO to a BD-R disc it will then play the movie on my LG BH200.....is there a trick to formatting the BD-RE correctly???......i use the Buffalo Mediastation to record onto BD discs..........the BD-RE disc only shows the LG BH200 set-up menu on the tv screen....thanks for the help..........
