As far as the sped up effect, do you perceive the effect as sped up if you put your 55 on CMD mode 3 for a live action (non animated) movie?
I have only watched a few scenes in a movie with CMD (3) turned on, since I don't like it for film. No sped up effect. I use CMD 3 for sports, e.g. UFC, and don't notice any sped up motion there either.
You just perceive the effect differently vs some of us in that case. CMD 3 on both my RS40 and RS45 I would describe as a sped up effect when used on film, so I understand when people describe it this way. I don't like or use it either for film.
Interesting. Could you suggest a movie scene I might look at with CMD on to spot this effect? (I have a lot of Blu-Rays).
Literally ANY live action movie I perceive the effect as sped up. I use mode 3 for animated films where I do enjoy this feature and dont turn it off until the next disc I put in. I always know immediately when I put in something live action (movie) if mode 3 is on as that sped up look hits right away and I have to go in and turn it off.
I will say that while I do notice this on my new BenQ W7000 as well, the FI on that machine is much better implemented in general vs JVCs version so it is not as dramatic. I can actually watch live action 3d (not 2d though) movies with FI on low on the 7000 which I know I could not do on the JVC (if CMD was an option in 3d which its not) considering how it is implemented. The JVC CMD breaks up once a pan gets to a certain speed and looses its composure. The 7000 really holds its composure in this situation much better and the low mode is just less aggressive in general. Combine all this with the better native motion on the DLP and a lot of my sped up perception is due to JVCs version of this feature I am sure. Edited by Toe - 1/10/13 at 2:46pm
I got a sign that says that this isnt available in my region. Thats not funny...
If you can access http://www.tunnelbear.com/ from your current region, you can download a free version of their proxy server that should give you enough data this month to watch that video and a few others as though you were in the USA. Or, for other reasons, in the UK.
Good thing it eas on the tube, downloading stuff on your computer is like leaving your drink unattended in the bar, even if I appreciate the help I got from you guys.
you of all people should have enjoyed the scene where they are assembling the dresser from ikea!
I think there was discussion on this earlier in the thread. They could definitely create a 720p60 Blu-ray of this, using 3:2 type pull-down (pull-up?) to change 48fps to 60fps.
There is no 1080p60 spec on current Blu-ray, so that would require new hardware.
1080/60i would also work.
1920*540 = 1036800 pixels
1280*720 = 921600 pixels
The other advantage is that your display only needs to scale/interpolate on one axis. And future TVs could be adapted to convert 60i to 48P.
But current 1080i60 is deinterlaced to 30p because the 540 pixel height frames are really just half of the same frame. Meaning that you can't get true 48fps out of current players and displays (except at 720p). Future displays could theoretically deinterlace it into 2 consecutive 540p frames, but that seems unlikely IMO.
