AVS › AVS Forum › Display Devices › Rear Projection Units › Official 2008 Samsung HL61A750/HL67A750 LED DLP Settings and Calibration Thread
Official 2008 Samsung HL61A750/HL67A750 LED DLP Settings and Calibration Thread - Page 13
post #361 of 554
Varus,
Whats your white balance at? after plugging in the settings mine shows -10? is this right? also whats your flesh tone? and digital NR? sorry for all the questions, just not sure on all the user menu settings! haha. Thanks Varus
post #362 of 554
Originally Posted by Dhupke21 View Post
Varus,
White Balance and Flesh Tone should be set to 0. NR is whatever you'd like. I put it on Auto for TV watching and Off for bluray
post #363 of 554
Awesome, thanks Varus, I figured they were at 0 was just strange how i put in your settings in the service menu and then went to my user menu settings and my white balance was at -10. Strange. Thanks for all your help. Im sure Ill be back with more questions. I think it looks amazing right now, watched SD Ironman last night upconverted through my samsung HT-Z410 and it looked amazinggggggggg...however the roomate and my gf think it looks dull/dark, especially on cable viewing(I think they are used to the LCD TV's and like that Bright POP that they have etc). haha oh well, my tv, my viewing pleasure.
post #364 of 554
Well it'll never have as much POP as the Vivid mode most LCD's have because, well, grass isn't supposed to be neon green Playing around with the LED levels shouldn't hurt color accuracy too much though so if you want to use High, go for it! Just realized that your blacks won't be quite as good. Some people also like Dynamic Contrast set to Low. I'm not a fan but as you said, it's your TV so whatever works for you! Glad you enjoy the settings!
post #365 of 554
Unless your able to lock the DP mode to Off in the Acterator service menu like mine. I get LED off blacks and brilliant brights, Just like then new Samsung OLED displays that go for over $3000.00. It took a long time of playing around with the service menu and F/W down grade to get it this way, but it works fine for me as summer day light viewing is an issue.
post #366 of 554
I am so tempted to do that but although I'm always up for playing with the service menu, I'm a little worried about a firmware downgrade. Out of curiosity, what F/W and service menu settings did you use?
post #367 of 554
I would also like to know what firmware you downgraded to. I have the firmware ending in 7, which one is the best one?
post #368 of 554
For what it's worth...I have the same firmware the Low Tech downgraded to. I cannot get that particular setting to stick. He has, but I'm not sure why mine will not.
post #369 of 554
Varus,
The same thing happens to me. I go into user menu and change my white balance to 0 then I enter the settings into the service menu and have expert settings on "movie" with LED on auto and shut down the TV. When I turn it back on, the white balance has changed to -10. If I used calibration mode under expert settings then all is good and whatever I input stays.
I think it has to do with having LED on auto but I am not sure.
post #370 of 554
I've had my HL67A750 for about 3 months now and it looks awesome thanks to you guy sharing your calibration experience.
Varus' settings are working quite well for me (firmware 1007.4). I made a few small adjustment with DVE + filters and the patterns look good to my eye.
As I was setting up to try Varus' updated settings, I accidently selected the "Calibration" item in the "DDP3021" menu. I was wondering if someone with a service manual could tell me what this options does. The screen flashed white three times (like it does when you do a "Color Sensor Save"). The only thing that I noticed was changed afterwards was that "CCA" was set to off, the picture was pretty much the same.
- Tom
post #371 of 554
What is the difference in setting the xy coordinates for the primaries in the CCA menu vs the desaturation menu?
post #372 of 554
The x,y,Y coordinates in the CCA menu are the measured RAW levels of the LEDs. Since these are non-standard primaries, the CCA is there to correct them as close as possible to where they need to be, by blending the primaries with each other.
The desaturation menu lets you tweak the coordinates for the gamut you are calibrating to.
post #373 of 554
Thanks Lee. In your steps to calibrating, you say to adjust the CCA settings if not using the factory ones. Do you recommend leaving those alone then? I am not sure how to know if I should use the factory CCA settings or not.
post #374 of 554
You will want to take a full set of grayscale and gamut to see how things look before you go changing those raw measurements. If they look reasonable, and you can adjust desat to get most of your colors under 3 in DE, then use that approach instead of changing the factory CCA RGB settings.
post #375 of 554
after calibrating my set looks so MUCH better, but the whites still have a slight pinkish tint. I can tell when watching NBA Basketball Games and when the camera is zoomed out the Player's white jersey's have a slight pinkish tone to them. I have the HL67A750 - what setting in the service menu can I adjust to help with this? I want the whites to look white. One of the APPLE, I am MAC/PC commercials with the white back ground came on and the white background was a bright white, it looked sort of washed out. Hard to explain. Thanks for the help guys!
post #376 of 554
Have you changed the WB settings on all the inputs? The WB is one of the settings that does not carry over and has to be re-enter on each inputs in the SM.
post #377 of 554
Since everyone is dong a lot of experimentation in the service menu, I thought I'd share the procedure for a full factory reset in case you screw something up.
1. Enter the service menu.
2. Go to the OptionByte submenu.
3. Activate WB Reset so that it says ”On” (it will turn Off automatically later)
4. Activate EEPROM Reset.
5. The TV will turn off. Wait a minute or two and then power on manually. When the set comes on, be sure to select the "Home" mode and not the "Store Demo" mode.
Also, you really should not be messing with the xyY RGB adjustments in the DDP3021 submenu. This is for calibrating the CCA system, not for calibrating the set's display performance.
BTW, I ordinarily don't discourage enthusiasts from doing their own calibrations. This is generally fine, if you are willing to purchase the necessary equipment, learn how to use it, and get an understanding of color science.
However, the Samsung DLPs have easily the most complicated calibration system of any display I have ever worked on. There are about a gazillion ways to screw it up. Also, the LED light engine means that inexpensive colorimeters are going to return less accurate results than they would with conventionally-lit displays. I measured an offset between my Chroma 5 colorimeter (which is the best of the affordable colorimeters) and my reference spectroradiometer of an average of x0.007, y0.004. That is a big enough variance by itself to make the difference between acceptable and unacceptable results. Add to that the normal unit-to-unit variation between commercial displays and the fact that the CCA system was not individually calibrated with a reference instrument, this means that simply entering the numbers obtained from someone else's efforts with an affordable meter will just as likely make your image worse rather than better. Given expectation bias and the lack of a reference against which to compare it, you could very well not even notice.
I just finished calibrating one of these and the client had punched in a lot of numbers he saw on this thread and the result was a considerably less accurate image than he would have had if he had just left it in the factory Movie mode, Warm2 instead of mucking around in the service menu.
post #378 of 554
Hey Tom, as one of the aforementioned enthusiasts, I thought I'd take this chance to ask you a couple of questions: First, when the primaries are calibrated accurately (according to my measurements which will obviously be off from someone using pro-grade equipment), the yellows are substantially off and cannot be further corrected, also the 75% saturation measurement in particular for each color is inaccurate. Did you notice this too, or is this just a quirk of either my tv or meter?
Second, after doing some research, I saw that the human eye was much more sensitive to x, y variation than it was to Y variation so in my latest settings, I tried to find a happy medium introducing some Y error into the primaries in exchange for more accurate x,y for yellow and the <100% saturations. Is my reasoning solid here or should I have just kept the accurate primaries and learned to live with the other errors I was seeing? Thanks in advance! I'm still trying to learn this stuff and this has been a fun TV to teach myself on!
post #379 of 554
Is there a place to download the latest firmware since Samsung has never made it available on its website? Thanks.
post #380 of 554
Originally Posted by tomhuffman View Post
also, you really should not be messing with the xyy rgb adjustments in the ddp3021 submenu. This is for calibrating the cca system, not for calibrating the set's display performance.
However, the samsung dlps have easily the most complicated calibration system of any display i have ever worked on. There are about a gazillion ways to screw it up. Also, the led light engine means that inexpensive colorimeters are going to return less accurate results than they would with conventionally-lit displays. I measured an offset between my chroma 5 colorimeter (which is the best of the affordable colorimeters) and my reference spectroradiometer of an average of x0.007, y0.004. That is a big enough variance by itself to make the difference between acceptable and unacceptable results. Add to that the normal unit-to-unit variation between commercial displays and the fact that the cca system was not individually calibrated with a reference instrument, this means that simply entering the numbers obtained from someone else's efforts with an affordable meter will just as likely make your image worse rather than better. Given expectation bias and the lack of a reference against which to compare it, you could very well not even notice.
i just finished calibrating one of these and the client had punched in a lot of numbers he saw on this thread and the result was a considerably less accurate image than he would have had if he had just left it in the factory movie mode, warm2 instead of mucking around in the service menu.
:d:d:d:d:d:d
post #381 of 554
I noticed that the secondaries (not just yellow) were off considerably more than the primaries after a factory reset and CCA system calibration. I had no problem correcting the errors with the Samsung service-level tools. White, however, was very accurate and required little adjustment. I only calibrated to 75% stim, 100% saturation targets.
Second, after doing some research, I saw that the human eye was much more sensitive to x,y variation than it was to Y variation so in my latest settings, I tried to find a happy medium introducing some Y error into the primaries in exchange for more accurate x,y for yellow and the <100% saturations. Is my reasoning solid here or should I have just kept the accurate primaries and learned to live with the other errors I was seeing? Thanks in advance! I'm still trying to learn this stuff and this has been a fun TV to teach myself on!
It is more complicated than this. We are more sensitive to some colors rather than others. Also, our sensitivity to changes in luminance are greater at lower levels than at higher ones. Having correct x,y points with high luminance errors can lead to very large dEs, so I wouldn't make any generalizations about tradeoffs. Just get the dE as low as possible.
post #382 of 554
Hey Tom, thanks for the response! I agree that all secondaries were off a bit after a reset, yellow just stood out because if I decreased Color or sub-color enough to get the primary Y values in line, it became impossible for me to get the yellow x,y accurate whereas the other secondaries could be easily corrected with the service menu options. As for the saturation, I calibrate to 75% stim, 100% sat also but at the end, I test 0%, 25%, 50%, 75% saturation just to see where they are and that's when I noticed the errors. 75% saturation is displaying closer to a 65% level.
The problem I had getting total Delta E as low as possible is that while the primaries were accurate, the yellow delta E was around 12. By increasing the color a little, the primary delta E's increased to about 4 (after x,y adjustment) but yellow decreased to about the same.
Thanks for taking the time to respond, every week it seems I find out something I didn't know before!
post #383 of 554
3. Activate WB Reset so that it says On (it will turn Off automatically later)
Can you post your before and after charts?
post #384 of 554
Well, "before" is a little problematic, because there were several befores: Before in Movie, Before in Standard, and Before after factory reset/CCA internal calibration, but prior to CCA adjustments. After is easier.
I have a review on my web site that includes charts.
http://www.displaycalibrationonline....samsungDLP.asp
post #385 of 554
Thanks Tom!
post #386 of 554
Very excited to have Dave Abrams cal my 67 today.. let you all know how it goes..
And thanks for the link Tom... when I first got my set, I posted about how disappointed I was in the black level.... others seemed to have the opposite impression.. reading you review made me feel better about my critical viewing skills.. (they've gotten pickier now that I have been mixing with a new Christy 2k D-Cinema projector... )
post #387 of 554
I'm back from an unfortunate exile. However, I am without my TV for the next two months. We are in the process of moving and our new home will not be ready until August. It has been sitting in a climate controlled storage unit since Saturday.
post #388 of 554
jrcorwin, do have an 60XBR2? I thought I remembered you posting there a couple of years ago. I have one also. I was also trying to get the 60 LED from Samsung but waited to long.
post #389 of 554
The way this TV works, it seems that the measured black levels are high, but I've yet to see a dark scene where it is gray, instead of the intended black, on program material.
This was an issue on the lamp based DLPs, as well as some current non-led backlit LCDs, or some current plasmas.
So, how did the calibration turn out?
post #390 of 554
if im running everything through my Onkyo 607 reciever and I only have one HDMI connected to the TV then I should not need to do this right?
  Back to Forum: Rear Projection Units
