I'm taking a hard look at the URC RF20 with RF base station on Amazon but had a couple of questions I couldn't find answers to.
1) On the MAIN buttons, where you can select a device, can those be programmed as macros? I'd love to be able to press DIRECTV to choose the device and then have it power on the correct devices. And then OFF could turn off everything. Not as good as activities from Harmony but close enough.
2) Can you disable IR output so it's just RF? My devices are behind glass and visible but the angles are horrible depending on where we sit so RF is ideal. But I'd hate to get double hits if you can't stop the URC RF20 from sending IR.
Thanks for any info.
Adam
Adam
