A bit confused here. I have seen several threads recently talking about thousands of Watts for subs. This does not make sense to me. The maximum output of a given driver is limited to it's diameter and xmax. All more power can do is rip the driver apart. I found I could reach xmax of my Peerless '500's easily with my DH220. (using my soda straw measurement). My RDs265 I can reach with my 30 W bench amp. for 100 Hz and down. Higher frequencies take more, but I am talking sub's here. Doing a bit of reading, Linkwitz has very detailed measurements to support my observations.
I can see a big 15 or 18 has to move more air, so it will take more watts to do that, but I can't see how a single cone can make use of more than 300 or so (8 Ohm reference). Offset a bit as they tend to be higher efficiency.
To play louder, it would seem you need more cones, not more watts
