AVS › AVS Forum › HDTV › HDTV Recorders › If recorderis DVI capable but your HDTV is not will the recorder still record in HD?
post #1 of 8
I was curious what the specs are for encryption on DVI/Firewire equipted recorders. If the recorder has DVI or Firewire to accept a HD signal from HD Satellite receiver (that also has DVI or Firewire capabilities) but your HDTV does not, will the recorder still record the FULL HD resolution but display it downres'd to the HDTV (and when the TV is replaced with a compatible HDTV it will then display full res) or will it record only a downres'd picture?
post #2 of 8
If the recorder was connected via 1394 firewire to a STB or ATSC tuner which was 5C compatable AND the programming was allowed to be copied, then yes, it would record full resolution and even output full resoltion via the component connections. If it is tagged "copy never" it won't record in the first place. The recorder may allow the copy never material to flow through the recorder out to the component jacks, but then it would be image constrained.
DVI is a non issue here because DVI is strictly a display device connection. You won't see DVI input prots on anything but display devices.
To summarize, if you can record it, then you can watch it in full HD resolution via analog connections. If it's not recordable, it must be watched constrained.
If your idea is to record premimum content and watch it later when you get a digital equipped monitor, it's not going to work.
There could be some exceptions to Image Constraint for the first few yaers where it is turned off while still keeping copy never.
post #3 of 8
It is technically possible to create a storage device that records DVI signals. However, if the DVI signal has been encrypted with HDCP, then the HDCP license agreement would prohibit the recording of that signal.
Some non-display devices such as switchers, splitters, scalers, converters, and extenders have DVI inputs.
post #4 of 8
Not quite true. There's are two recordable modes, "Copy Freely", which I think you're talkin about and "Copy One Generation". "Copy One Generation" content is encrypted and must be image constrained for analog HD output, unless it also contains "Image Constraint Tokens" (a flag within an MPEG-2 TS extension packet).
-- Mike Scott
post #5 of 8
Moving to HDTV recording.
post #6 of 8
You won't see DVI/HDCP inputs on anything except displays (or possibly repeaters). The DVI/HDCP licensing agreement is pretty strict about this.
-- Mike Scott
post #7 of 8
Switchers, splitters, scalers, converters, and extenders are all examples of repeaters.
Quotes from the HDCP LA:
“Repeater†means a Licensed Product that has a “Repeater Function,†which is the capability to receive, decrypt, re-encrypt and re-transmit HDCP Content to one or more outputs, in accordance with the HDCP Specification.
Decrypted HDCP Content may be temporarily buffered to enable and perform the Repeater Function or image processing function (e.g., picture-in-picture display, image overlay, image enhancement and brightness adjustment), provided that such buffer shall not persist for more time than is necessary to perform such function.
post #8 of 8
If I have a digital display with only one DVI/HDCP input and have two receivers with DVI/HDCP outputs, are there any switches which will let me change sources?
Currently I have two receivers with component outputs. I connect them through a switch to the one component input on my HDTV.
Will I be able to do this with DVI/HDCP connections?
  Back to Forum: HDTV Recorders
This thread is locked
