Guys my setup is Denon 2809 AVR and Denon DENON DCM-500AE CD player, I am new to Custom Home theater Hifi setups, what should I be doing letting the player Decode the Adio and sent it to the receiver through Analog, or Use Optical and let the receiver do the decoding?
Any advice is appreciated.
Cd player specs -
Specs:
Width 43.4 cm
Depth 27.9 cm
Height 10.7 cm
Weight 4 kg
Audio D/A Converter 24bit / 192kHz
Total Harmonic Distortion 0.003%
Display Dimmer
Optical Digital Output
Playback Modes include Programme play, A-B repeat, random play / shuffle, all tracks repeat, one track repeat
Response Bandwidth 2 - 20000 Hz
Signal-To-Noise Ratio 105 dB
Dynamic Range 98 dB
CD Track Programming (25 tracks)
CD-R/CD-RW Compatible
CD-RW Compatible
Infrared remote control x2
Cd player specs -
Specs:
Width 43.4 cm
Depth 27.9 cm
Height 10.7 cm
Weight 4 kg
Display Dimmer
Dynamic Range 98 dB
CD-RW Compatible
