AVS › AVS Forum › Display Devices › Rear Projection Units › Samsung HL67A750 and 3D?
Samsung HL67A750 and 3D? - Page 4
post #91 of 204
I just received my x102 glasses today along with the Panny BDT-300.
I have the Samsung DLP A750 and this combo works great!
Only have the demo disc but its awesome!
Bob
post #92 of 204
Ok so I have the HL67A750 also and I want to go over what I need.
Mitsubishi 3DC-1000 3D HDTV Starter Pack
Xpand 3D Shutter Glasses
and a 3D blueray player (and receiver which I'm going to get).
Anything else I need? Fry's has the Mitsu starter pack for $226 so I'm gonna get that there, order the glasses online. And shop around for a 3D bluray player. I'm curious why my TV won't beable to do 3D gaming on the PS3? I know that in september PS3 will get a firmware update that will allow it to play 3D bluray movies. So would that work for the B3D movies?
Can I get a laymen's quick rundown on what I need, and a general Idea of what I'm gonna hook up to what.
post #93 of 204
Thhe Mits adapter only works with Mits TVs - it checks the EDID from the TV. You need a Gefen EDID clone device and a Mits DLP TV to get the EDID info from. Go to the 3D threads for more info.
post #94 of 204
If you plan on getting the Xpand glasses, why would you get the Mits starter pack (which includes glasses)? Just get the Mits adapter, the Gefen adapter, and Xpand glasses.
post #95 of 204
frys doesnt have the mits starter pack for sale called sais it would be back in stock 2to 3 weeks
post #96 of 204
Also, if you're just getting the Xpand as extras, they aren't compatible with the Mits, they require the TV to be in the opposite mode.
If you're going with the "3DA1+Gefen+HL67A750=3D" then you'll probably want to read through the entire thread of that name to get an idea of the issues involved, equipment required, and steps to follow.
post #97 of 204
I have read through it and I know I need the Mitsu Adaptor, Gefen HDMI Detective, and 3D glasses that are DLP-link, whatever that means. The problem is when I call Fry's or BB the dummies have no idea which glasses are, or what DLP-Link even means. Which is why I need help figuring out what glasses to get.
post #98 of 204
You don't have to get DLP-link glasses. If you got the Mitsu starter kit, it would come with glasses and an emitter, and those would work fine. If you are just getting the adapter, not the starter kit, then you could either buy glasses + emitter separately, or you could buy DLP-link glasses. The only DLP-link glasses I am aware of at the moment, are the Xpand X-102, or the Viewsonic glasses (which I haven't seen in-stock anywhere yet, also have not confirmed they work with our sets).
The other thing to note is if you are buying a new 3D-BD player anyway, you could just get the panasonic BDT350 player that outputs checkerboard, and not have to deal with the adapter issues at all. In that case, you could once again either get glasses+emitter, or get DLP-link glasses. The advantage of glasses + emitter is that they would be compatible with the newer 3D TVs in case you decided to upgrade in a year or two. The DLP-link glasses will only work with DLP TVs (and DLP projectors). The DLP TVs however, can work with any kind of glasses.
I was just going to add a link to the panasonic 350 player at Amazon, and went searching and they don't even have it listed available new anymore, not out-of-stock, in-soon, or anything, just one seller with a used one
post #99 of 204
The panny bdt 300 is similar and much cheaper
post #100 of 204
FYI everyone:
Check out the Samsung DLP 3D kits available through TRu3D
http://www.tru3d.com/3D_Accessories/3D_Converters.php
Everything is included to get one up and running.
post #101 of 204
Excellent point. The 750 is two years old already and your next display may well not be a DLP.
If you want to go with DLP Link glasses, the Optomas are a good alternative because they don't require special batteries available only from Xpand who charges exorbitant shipping fees.
That said, I use Xpand 102s with my HL67A750, but only because I'm getting a Mitsubishi DLP for my other residence. Additional glasses will definitely be Optomas.
Buzz
post #102 of 204
will this work?
post #103 of 204
i mean the tru3d kit? it says for dlp 3d tv's and ps3
post #104 of 204
Ive read through most of the posts but A- i don't know much and its kinda of confusing, and B- my case load at work is horrable and i dont have a lot of time to research, so what im asking is does someone have a definate list of what WILL work awsome for the a750 for 3d. and last has been used and proven. And will it work in the future with a newer tv?
post #105 of 204
Anyone??
post #106 of 204
If you only want to watch BD movies then get a Panny 300/350 BD player which will output checkerboard directly to your set. The only thing else you will need are DLP-Link glasses.
If you want 3D broadcast you need both the Mits adapter, the Geffen spoofer, and 3D glasses. This will also work with a PS3 after the expected FW upgrade in September.
There are other considerations such as splitters and switchers depending on your equipment.
What exact 3D do you want and is your AVR 3D or not?
Buzz
post #107 of 204
No i have a denon avr 790 i think ill have to look when i get home, I have a ps3 and a HTPC i built i just want to see 3d, I usually watch movies from a HD that is on my HTPC but use Tv versity and watch through my ps3. I would love to be able to BD 3d and all of my movied that r on my HD. It took forever top condence my dvd disks. I hope that wasnt for nothing. lol also what glasses would i need? THanks so much
post #108 of 204
If you're using a HTPC, you need a software 3D BD player (like TMT or PDVD), and glasses.
For glasses, I'd suggest the Xpand X102's.
post #109 of 204
Wow this is all really great news. Thanks for keeping us updated!
post #110 of 204
Ok well if i don't use my htpc what do i need so that my tv is 3D. It would be nice if what ever is playing through the tv its 3D is that even possible?
post #111 of 204
No, it is not possible. No 3D content, no 3D. There is no 2D>3D conversion feature on the HLXXA750 displays.
Buzz
post #112 of 204
ISn't that what this thread is for??? 2d tv putting out 3D??
taz in your opinion what is my check list of items to buy for 3d.
post #113 of 204
what glasses and what emitter are you suggesting? i was told by a kid in bb that the bdt 350 would not work on my tv?
post #114 of 204
The kid is wrong..
Panasonic BDT350 player outputs checkerboard
post #115 of 204
Go figure..lol i think te problem with some of those "TV PEOPLE" in BB they don't know a whole lot and give a quick answer,
post #116 of 204
Anyone
post #117 of 204
Anyone
For more Info:
BUYERS GUIDE: 3DTVs and 3D Active Shutter Glasses
Read or Post Here..
3D Shutter DLP Glasses: REVIEWS
post #118 of 204
ok well can anyone tell me what THEY have and use that works for the 67a750 and where i can get the same thanks
those postings have little to NONE on the samsung that i own. its mostly for mits, thats how i bought a system and it didnt work, thats why i have come to this one because this is just for the sam67a750!
post #119 of 204
I have a legacy Samsung HL67A750 DLP and a Panasonic DMP-BDT350. For glasses I'm using the ViewSonic PGD-150. They work fine with this setup. I ordered both the Panasonic and the ViewSonics through Amazon.
post #120 of 204
So I just got my x102 and I've been playing Pandora on my 67a750. The 3d works pretty well. The only thing I noticed was at times during the game the thing would seem to go out of sync. Basically the 3d would stop working and then sync back together again.
Anybody else having this problem? Or do I have a bum pair of glasses? Also what is the deal with no off switch? Its kind of a weird setup for turning them on and off.
Still on the fence on whether to use true3d's setup.
  Back to Forum: Rear Projection Units
