The Channel master CM7000 and Tivax STB-T8 are reputed to be two of the top rated boxes.
Frankly I am amazed! The BEST? Really???
That's hard to believe, given the really annoying issues that plague both these boxes.
I think that most of these issues have been reported by others, but I was a little surprised that the manufactures have totally ignored these complaints and never bothered to fix them.
For example, despite the CM7000's supposedly 'best in class' video, I have found that on each and every one of the channels I am getting, the sharpness of Channel Master CM7000 on S-Video is very disappointing.
When downsampling 1080i HD to S-Video the result should be AT LEAST DVD QUALITY (and potentially much better). The CM7000 picture does have good color, and is very smooth and clean with low-artifacts, but the Tivax STB-T8 1080i HD composite conversion output is actually SHARPER than the CM7000 is on it's S-Video output!
Composite should never be better than S-Video, even if your set has Comb filters. Nor is this because my Sony Trinitron set has poor S-Video performance, it's great on S-Video. I have had several DVD players and a Satelite hookup on this set in the past, and ALL were MUCH sharper than the CM7000. It's so bad, some of the channels are actually sharper ON THE ANALOG OFF THE AIR TUNER than their ATSC DTV counterparts. Sad, really sad!
Second, I am also very disappointed in the CM7000 teeny, teeny, teeny, tiny, tiny, tiny, channel guide text. This ridiculous situation with the guide makes one of the boxes best features pretty much USELESS on small portable screens (or even on larger screens when using the tuner for input). You can't even read the damn thing! If you look at the screen shots of the channel guide of the CM7000 posted elsewhere on this forum, you will see that this is really, really, really, STUPID because they didn't even use anywhere near all the available space, and the guide screen is shifted way over to the left! The box supports several larger fonts for close captioning, but they were not used for the guide, EVEN THOUGH THERE WAS PLENTY OF SPACE. Whoever the MORON was at Channel Master who signed off on this should be fired!
Not that the Tivax STB-T8 is any better . . .
- The Tivax T8 channel guide is also pretty BAD because of it's poor layout (but at least the text is larger). Unfortunatly, you only get a lame now/next view - with only 4 frigin lines of text - then it chops off! When someone questioned this on the Tivax website FAQ, some idiot explained that "That's how it's designed to work" like that explained EVERYTHING. This is like picking up a new car, driving 4 miles, and having the engine fall out, only to be told tersely "you should have read your owners manual, the engine is SUPPOSED to fall out every 4 miles!"
- As mentioned, although the Tivax STB-T8 composite video is a bit sharper than the CM7000, it's still not DVD quality, epically on SD sub-channels (even SD channels encoded at full 704x480 DVD equivalent resolution!).
The T8 is also very poor at properly scaling the video. On HD it will NOT remember the correct zoom ratio, which is annoying, and on SD it's even worse, and can't even get it right after you try to set it manually!
Manufactures like Tivax like to say that their boxes aren't broken, they are just failing to offer an optional 'auto aspect' feature, but this is GARBAGE. The friggin FCC requires in the overall requirements, that the box –
A. Comply with the MPEG2/MPEG4 standards (which require that the decoders in the boxes deal properly with non-square pixel aspect ratios).
and
B. At a minimum, at least duplicate the basic functionality of the original NTSC system. I don't know about you, but I don't remember having to constantly fight with my old NTSC analog television set to keep the picture from alternately turning into a tiny postage stamp, or blowing completely off the screen (or showing a screwed up distorted picture with FAT or SKINNY people).
Not only does the Tivax T8 fail to automatically deal with the pixel aspect ratios correctly, but it also screws them up on 4:3 SD content EVEN AFTER YOU SET THE PROPER ASPECT RATIO MANUALLY (you get none square display with taller skinner people, or alternately fat stretched people; no setting gives the correct 1:1 aspect ratio).
The good news is that (at least for the Tivax STB-T8), I think that owners may be able to force a software upgrade, because the whole argument about whether ‘auto setting’ is required is moot when you can’t even set SD content to a correct 1:1 aspect ratio manually.
Part of the most basic requirements for any CECB is MPEG2/MPEG4 compliance, and those standards require proper handling of all the standardized non-square aspect ratios PERIOD - END OF STORY.
Tivax can try to B.S. about how so-called 'auto aspect' is not actually called out in the standard, but as I said above, that's ridiculous, the user should not have to punch an extra 'aspect' button up to three times just to keep the set from displaying a totally non-compliant picture with incorrect horizontal/vertical scaling! In any case, you can’t even get it perfect by setting it manually, so I’d like to see them weasel out of that!
If these boxes are two of the best, I'd hate to see some of the worst!
- Delphin
and
- Delphin
